Latest post Thu, Jun 18 2015 4:26 PM by Susi. 24 replies.
Page 2 of 2 (25 items) < Previous 1 2
  • Thu, Aug 23 2012 4:51 PM In reply to
    Re: timecode burn-in
    Kenton.VanNatten:
    You don't have an effect named Timecode in your IllusionFX category?
    No, I don't. Where else could it be? The only timecodes I see are under Generator
  • Thu, Aug 23 2012 4:59 PM In reply to
    ekuseni:
    The plugin looks good, but since I'm not an expert with computers, I'm always leery about adding something to my system when the sytem is working well. It may be unfounded worry, I may be paranoid, but it does give me pause.
  • Thu, Aug 23 2012 5:07 PM In reply to
    Ben Wilson:
    What some of our producer/editors have done in the past for sending out video for transcribing is to place the clips to be transcribed on the timeline.  Drop the timecode effect on an empty video track above the clips.  Set the effect to display the source clip's timecode and the source clip name.  The timecode displayed then changed to the visible source clip along with the source clip name for the transcribers to use as a reference.  Not sure if that would do what you need if you have multiple video layers, but it may.
    Ben
    Thanks. Timecode on an empty track might be a solution for me. I'll have to play with that and see if I can figure out how to make it work.
  • Thu, Aug 23 2012 5:25 PM In reply to
    Enable Aux TC2 in the source bin
    Enter 0 in Aux TC 2 column for the clips.
    Add generator on the track above.
    Choose Other Counters.
    Current Track
    Auxiliary TC2
    This I think will give you what you require.
    Symphony 2018.12.13 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona Lhi. MC 2018.12.13 OS 10.13.4 Mac Pro 5.1 2x2.97 6-core 32GB ram Aja Kona 4, SNS SANmp 2x Infortrend... [view my complete system specs]
  • Thu, Aug 23 2012 6:49 PM In reply to
    David Yardley:
    Current Track
    Auxiliary TC2
    Wonderful! That seems to work! Thank you, David, and all who have responded!
  • Thu, Aug 23 2012 6:54 PM In reply to
    Kenton.VanNatten wrote the following post at 2012/8/21 9:32 AM::
    You could set Aux TC
  • Fri, Aug 24 2012 3:30 AM In reply to
    Kenton.VanNatten:
    Sorry either I didn't catch that or understand it at first. Also I was contemplating your question as to the difference between source set to zero and sequence set to absolute. It's all new to me. Thanks for the help.
  • Wed, Jun 17 2015 1:39 PM In reply to
    • EAFutter
    • Joined on Thu, Apr 28 2011
    • Posts 14
    • Points 170
    It's actually in the Effects Palette under Generator.
  • Thu, Jun 18 2015 2:19 PM In reply to
    John William:
    Kenton.VanNatten:
    Wow, I just saw the updated comment posted here - I guess my email filtering for the forums is wonky. Sorry I didn't see your response before. Hopefully, you've figured it out in the last 3 yrs.
  • Thu, Jun 18 2015 4:26 PM In reply to
    • Susi
    • London, UK
    • Posts 609
    • Points 7,105
    You could get rid of the 'hour' digit by moving the TC window over to one side when setting the FX parameters like font size, position etc.... A kindergarten/nursery school solution that took me years to think of, in order to cut the frame numbers off in BITC if making playouts for translators; poor things, seconds are precise enough
    MCversion 2020-10-0 on macOS 10.14.6 13" early-2015 Macbook Pro; 3.1GHz Intel Core i7, 16GB 1867 MHz DDR3 Intel Iris Graphics 6100 1536 MB [view my complete system specs]
