Latest post Thu, Aug 29 2024 12:54 PM by Marty. 51 replies.
Page 2 of 4 (52 items) < Previous 1 2 3 4 Next >
  • Mon, Sep 23 2013 10:54 PM In reply to
    • Evan Schiff
    • Los Angeles
    • Posts 121
    • Points 1,475
    Re: Audio Crossfade behaviour MC 5.5
    It's still in v7, too. I've learned to work around it by adding a keyframe to the other side of a dissolve if one of the sides already has one. But I just hit an instance 5 minutes ago actually where that didn't work and I had to move my B-side clip to another track and then put identical dissolves at the cut point on both tracks.
    I read somewhere that part of this behavior is intentional, but I don't understand why that would be since it worked as you expected it to in earlier versions
  • Tue, Sep 24 2013 3:12 PM In reply to
    Evan Schiff:
    I've used the split track method as well and adding the other keyframe but neither is ideal especially when you are trying to minimise tracks.
    I can't believe it is an intentional change. We gained nothing by this new behaviour.
    MC 8.8.2 OSX 10.12.3 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Tue, Sep 24 2013 6:11 PM In reply to
    • dyllio
    • Los Angeles
    • Posts 57
    • Points 600
    Agreed! This has been a "known bug" for too long now and it's incredibly frustrating (apparently since the v5 update 3 years ago).   At least with v6.5 and up, we have more tracks to 'waste' trying to work around this bug, but it's very annoying when you bump into it.  Each editor I've assisted has bumped into this bug and complained.
    Mac Pro 2 x 2.66 Ghz 6-Core Intel Xeon, 16Gb RAM, Mac OS 10.7.2, MC6.0.1.1, NitrisDX [view my complete system specs]
  • Tue, Sep 24 2013 6:26 PM In reply to
    As I wrote earlier, it had been logged as a bug, I pinged MM to check the status of UDevC00172587.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Tue, Sep 24 2013 9:35 PM In reply to
    I hear this issue is still on the list, folks. Hopefully in an upcoming patch.
  • Fri, May 23 2014 6:05 PM In reply to
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 997
    • Points 11,765
    Hello, I'm working with 7.0.4 and I still have issues with dissolves / audio keyframes. Sometimes render helps but sometimes not. It seems like the dissolve is ignoring the auto gain value.
    www.film-editing.de
  • Fri, May 23 2014 6:51 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 997
    • Points 11,765
    here you can see a demonstration of the behaviour:
    http://vimeo.com/96235665
    www.film-editing.de
  • Fri, May 30 2014 8:12 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 997
    • Points 11,765
    This is so annoying, is there any chance to see a bugfix pretty soon?
    www.film-editing.de
  • Fri, May 30 2014 8:25 PM In reply to
    • dyllio
    • Los Angeles
    • Posts 57
    • Points 600
    One thing I've noticed in recent versions is that if there are rubberbands on both the incoming and outgoing clip, MC seems to playback the dissolve correctly in real-time without editing.  Are you seeing that?
  • Fri, May 30 2014 9:48 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 997
    • Points 11,765
    Unfortunately no, the dissolve seems to ignore both auto gain values on incoming and outgoing clip.
    www.film-editing.de
  • Wed, Jun 11 2014 11:12 AM In reply to
    Has this bug been officially scheduled for a fix yet? It is incredibly bad that a pro editor can't do a simple crossfade correctly. it's been a bug for 4 generations of the software now.
  • Wed, Jun 11 2014 12:12 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,514
    • Points 18,890
    I have to admit this thread has me scratching my head.  When I need the precision of cross fading while simultaneously changing clip volume it would never occur to me to not create an additional audio track.
    i9 12th generation, GeForce 3070, 64GB RAM [view my complete system specs]
  • Wed, Jun 11 2014 2:04 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 997
    • Points 11,765
    With the limited amount of audio track you can't always split your audio, if it looks like that for example:
    http://www.evanschiff.com/bd/wp-content/uploads/Reel-7-Full-timeline.jpg
    And sometime I don't use dissolves as a precision of cross fading, but only as a dissolve to not hear the edit. For example if you have an atmo and you want to bring some variations with keyframes so it's not getting to boring and you want to loop it, I need the dissolve only to hide the edit at the loop point. Or you want 2-5 frames dissolves for the dialogue that you carefully prepared with audio keyframes.
    www.film-editing.de
  • Wed, Jun 11 2014 2:22 PM In reply to
    • smrpix
    • Posts 1,514
    • Points 18,890
    Bloersch:
    Dude! You can still add 8 more tracks there! Wink
  • Wed, Jun 11 2014 2:27 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 997
    • Points 11,765
    You want to save some tracks to move some larger clips (Atmo, music etc.) there, so when you are trimming with sync locks enabled they don't get split and the rest of your timeline stays in sync.
    www.film-editing.de
