Latest post Tue, Dec 20 2011 5:27 PM by Marianna. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Nov 18 2011 4:56 AM
    Trimming MC6
    So I'm using the trim tools on mc6, is it supposed to preview what your about to overwrite or trim in the player windows, because when i do all i see is the numbers on the window that say how far im going, e.g. -12 etc., the preview hangs on one frame, but when i finish the edit it works, i just cant preview it. is this supposed to happen. the preview works when im sliding a clip with the overwrite tool to replace another portion of a clip though, it shows me which part im going to overwrite, thats what i dont get.
  • Fri, Nov 18 2011 1:52 PM In reply to
    • LewS
    • West Palm Beach, FL
    • Posts 10,277
    • Points 132,900
    • Moderator: MCA PC
    Re: Trimming MC6
    Yes. I have seen this also. I will escalate it to Avid. Instead of using the trim rollers on the timeline, use the keyboard trim keys or use the trim buttons in the trim editor. You should see the viewers update when you do this.
    3.15GHz E8500 CPU, Intel MB w P35 chipset, 4GB memory, Pioneer DVD burner, onboard audio, nVidia Quadro FX1700 512MB , 2TB (4 x 500GB) Raid 0 on Vantec... [view my complete system specs]
    LewS
  • Fri, Nov 18 2011 3:58 PM In reply to
    • eddie7
    • Joined on Thu, Sep 4 2008
    • Houston, Texas
    • Posts 15
    • Points 235
    Re: Trimming MC6
    I'm having this same issue as well.  It's the first big bug I've found with v6.
    Media Composer 7.0.3 on Win 7 SP1, Xenon Quad, 16Gb RAM, Quadro K4000, HP Z420 [view my complete system specs]
  • Fri, Nov 18 2011 6:39 PM In reply to
    Re: Trimming MC6
    so i guess it isnt just me. yeah, this is a horrible bug, i mean the trimmer is a huge part of editing too........
  • Tue, Nov 22 2011 9:52 AM In reply to
    Re: Trimming MC6
    okay i have found a fix. im not really sure if this is still a bug BUT in the viewer/canvas window, click on the trim mode button, then when your in trim mode, right click the viewer/canvas window and click on trim mode settings, then click on the Features button, select "Render on the fly" and deselect "Dual Image Play" if its selected. itll update as you trim using your mouse now.
  • Thu, Nov 24 2011 12:49 AM In reply to
    • LewS
    • Posts 10,277
    • Points 132,900
    • Moderator: MCA PC
    Re: Trimming MC6
    OK. I have tested this and it does work.
    LewS
  • Thu, Nov 24 2011 3:05 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,469
    • Points 98,700
    Re: Trimming MC6
    It may work, but it's an awfully roundabout way to do something that should be simple.  I hope this bug is in the 100+ fixes being addressed at the moment.
  • Thu, Nov 24 2011 1:09 PM In reply to
    • LewS
    • Posts 10,277
    • Points 132,900
    • Moderator: MCA PC
    Re: Trimming MC6
    I am pretty sure it will be but for now this is a workaround until it is resolved.
    LewS
  • Thu, Nov 24 2011 7:25 PM In reply to
    Re: Trimming MC6
    I get this too - iMac on 10.6.8. I thought I'd tweaked the Trim Settings but I'll go back and try the fix.
    iMac i5 27", 40GB RAM, OS 13.7 with MC 2024.10 with Symphony option, BlackMagic 4K. 2020 MacBook Air with MC 2022.7 ... and NewsCutter 7.x on Dell... [view my complete system specs]
    ACI, Dorset, UK. www.avid-companion.co.uk
  • Wed, Dec 14 2011 4:34 PM In reply to
    • itzawrap
    • Chicago
    • Posts 47
    • Points 655
    Re: Trimming MC6
    It's a BUG and a big one at that.
    This is not the way trim mode is supposed to work, nor shold one have to do all these contortions to make it work.
    Ought to be fixed, better be fixed!!!!!!
    MacBook Pro 17inch, 2,2 gig i7, Radeon HD 6750M 1024mb Vram, Yosemite 10.10.5, 1TB hd, 16gb ram, MC v8.4.3, SuperDrive, various ext drives... [view my complete system specs]
  • Mon, Dec 19 2011 4:43 PM In reply to
    • jpottenger
    • Grand Rapids, MI
    • Posts 39
    • Points 520
    Re: Trimming MC6
    Yes this fixed it.  Thanks for the help!  Definately a Major Bug in MC6.
    Media Composer 2022.7 | AMD Ryzen 9 3900x 3.80 GHz, X570 Aorus Master, 64GB DDR4 RAM, GeForce RTX 3070 Ti. Windows 11 Home 64-bit OS [view my complete system specs]
  • Tue, Dec 20 2011 5:27 PM In reply to
    • Posts 12,122
    • Points 262,115
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    Re: Trimming MC6
    This one is fixed in the first patch coming in January.  Not sure of the exact date but it is coming....
    marianna
    Sr. Director | Customer Experience and Community [view my complete system specs]
