Latest post Sat, Oct 13 2012 8:54 PM by Torx. 3 replies.
  • Thu, Nov 17 2011 12:29 PM
    • Torx
    • Joined on Sun, Oct 30 2011
    • Posts 9
    • Points 85
    MC 5.5.3 1080p24 project is recognized by Aja IO Express as 1080p24sf (=psf), output on consumer HD TV doesn't work
    In MC 5.5.3 a 1080p24 project (columns show 1080p24, 24 frames, DNXHD 36, color space 709) is recognized by Aja IO Express as 1080p24sf (in AJa terms, means psf) and output on a consumer HD LCD TV (Sony Bravia 32EX520, which is in color space 709 mode) over HDMI doesn't work. Only once the Sony showed format not supported. AJA IO Express Test Patterns in 1080p24 will be output on the Sony over HDMI (but not in analogue Comp. SMPTE/EBU) without problem. 8 or 10 bit makes no difference in the 1080p24 project. A 625i project will be output from MC, Aja and Sony without problems.The delivered Aja 9.1 driver didn't work, I had to downgrade to Aja 9.05 driver, Aja firmware used is 05/18/2011. I'm  on Mac 4.1 (2009) Dual Quad 2,26 GHz, 8 GB, SSD, OS 10.6.8, Radeon 4870. Thanks for help!
    MC 2018.12.15, MacBook Pro 2015, 2,5 GHZ Intel Core i7, 16 GB, SSD, OS 10.14.6, Radeon R9 M370X, Aja IO Express [view my complete system specs]
  • Fri, Oct 12 2012 6:06 PM In reply to
    • sven2615
    • Joined on Wed, Apr 12 2006
    • Berlin / L.A.
    • Posts 161
    • Points 2,190
    Re: MC 5.5.3 1080p24 project is recognized by Aja IO Express as 1080p24sf (=psf), output on consumer HD TV doesn't work
    I'm having the same problem here. U got any solution?
    Cheers sven
    some specs: mc5.5.3, eizo foris, project 1080p24, Mac, Aja io express, driver 9.05 (everything worked fine with Matrox mxo2mini)
    Avid Media Composer 2022.7 | MacStudio Ultra 128GB RAM | OS 12.6.6 | Avid DNxID [view my complete system specs]
    www.iconictalentagency.com/sven-budelmann
    www.svenbudelmann.com
  • Sat, Oct 13 2012 4:40 PM In reply to
    It's possibly that your monitor will not support a 48Hz vertical refresh rate.
    Sent the Sony Bravia model that I tried back for that very reason.
    Sorry if that's the case.
    Professional Panasonic series do, and possibly others.
    Symphony 2018.12.13 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona Lhi. MC 2018.12.13 OS 10.13.4 Mac Pro 5.1 2x2.97 6-core 32GB ram Aja Kona 4, SNS SANmp 2x Infortrend... [view my complete system specs]
  • Sat, Oct 13 2012 8:54 PM In reply to
    • Torx
    • Posts 9
    • Points 85
    I bought a Sony LMD 2110 W Professional Video Monitor (very small delay too), but in MC 6.5, you can switch the video output from psf to true p.
