Latest post Tue, Jul 19 2011 4:04 PM by Job ter Burg. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Jul 19 2011 2:07 PM
    • ibbymiiro
    • Joined on Tue, Jul 19 2011
    • Posts 4
    • Points 40
    RED AMA imported clips turning orange after Autosync
    Hi all
    I am having some major issues working with RED. I import my R3D clips using 'link to AMA' and once in the Avid I import my audio which has matching TC. I then use Autosync and select sync using TC but the resulting sub clip that Avid creates in orange. I have tried this on different suites and the results are the same, also i have had someone off-site try to sync the R3d files and they get the same results.
    if I try to batch transcode the clips Avid Crashes, also if I try to transcode with Metafuze it also crashes.
    Has anyone expreiced this issue and know of how to fix this.
    Avid MC 5.51
    Quicktime 7.6.9
    RED clips @ 25fps
    thanks in advance for all you help
  • Tue, Jul 19 2011 2:10 PM In reply to
    Re: RED AMA imported clips turning orange after Autosync
    Does the image turn orange, or does the color code of the clip turn to orange?
  • Tue, Jul 19 2011 2:16 PM In reply to
    Do you know what build of RED camera was used?
    Can you upload a short clip that causes the crash for you?
  • Tue, Jul 19 2011 2:56 PM In reply to
    • ibbymiiro
    • Posts 4
    • Points 40
    Hi Job
    The image turns Orange, and in 'set sour setting' on the subclip all i get is black.
    ibby
  • Tue, Jul 19 2011 3:17 PM In reply to
    • ibbymiiro
    • Posts 4
    • Points 40
    Hi Pat
    I have uploaded a sample onto vimeo here (http://vimeo.com/user909042/videos )
    I am know it was RED ONE. I am trying to get more info will post ASAP
    thnaks again
  • Tue, Jul 19 2011 3:32 PM In reply to
    • ibbymiiro
    • Posts 4
    • Points 40
    Hi  Pat
    The Red Camers is  Build 30.6 or 30.7 with the latest colour science.
  • Tue, Jul 19 2011 4:04 PM In reply to
    What happens if you select the synced clips, right-click and choose 'Refresh' -> Source Settings? I also notice the format of the clip changes. Can you set it to 'Letterbox' in the Reformat column of the bin?
