Latest post Tue, Oct 2 2012 7:09 PM by SamEllens. 2 replies.
  • Mon, Jul 11 2011 4:53 PM
    • Mr.Lemus
    • Joined on Mon, Jul 11 2011
    • Posts 1
    • Points 15
    Trouble with EDL manager
    Hi there! i'm new in this community, this is my first post, and i have a trouble with my project. I go to Output - EDL - in Avid EDL Manager i click in Get Sequence, and this error appears.
    Encountered exception 'Exception: DISK_INVALID_FILENAME_SYNTAX, filename:MVI_5481 '
    When i continue on import, appears this error:
    The AAF file received by EDL Manager is not valid. Get Sequence failed.
    I try this things to solve the problem:
    -I rename the name of file
    -I change the name of mxf
    -I eliminate the file and mxf.
    Conclusion:
    I've the same error, i don't know what else to do.
    Another question:
    When i export in aaf i have this report:
    Some destinations specified in the export options are not avaliable:
    Destination for consolidated, transcoded, mixed-down, or copied video media is locked [dl->GetFileLock()]
    Thank you and
    sorry for the inconvenience.
  • Mon, Jul 11 2011 5:39 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,745
    Re: Trouble with EDL manager
    Often the trick to getting EDL manager to work is to use the following workaround.
    1: Open EDL manager
    2: Select "open" under the file menu
    3: Point to the bin with your sequence in it inside the Avid project
    4: if it is the only sequence in the bin, it will automatically load. If there is more than 1 sequence, it will ask which one you want.
    Good luck.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Tue, Oct 2 2012 7:09 PM In reply to
    • SamEllens
    • Joined on Tue, Sep 6 2011
    • Posts 12
    • Points 150
    I know this thread is ludicrously old, and sorry for the bump, but the "Get Sequence" option has always driven me bonkers and using this method has resulted in my first hassle free EDLs in Avid.  Thanks!
    Our workstations: HP Z840, Dual 14s, 64GB, Titan X My portable system: MacBook Pro, Quad i7, 16GB, 750m Currently on MC 2018.8 [view my complete system specs]
