Latest post Thu, Mar 7 2019 3:01 PM by mnbkyle. 15 replies.
  • Mon, Jun 27 2011 11:28 PM
    • MosesN
    • Joined on Tue, Sep 7 2010
    • Posts 79
    • Points 855
    Exception: DIDReader::XraiseUnexpectedStreamStatus async file system error
    ExceptionDIDReader::XraiseUnexpectedStreamStatus async file system error
    Keep getting this error when exporting to HDV device, haven't made any progress. Last outputed 2  months ago with no problem.
    Anyone else seen this error message before when exporting to HDV tape?
    MC 8.3.1 OSX 10.9.5 QTPro 7.6.6 / 2010 MacPro 5,1 2x 2.93GHz 6-Core Intel Xeon / 28GB RAM / ATI 5870 1GB [view my complete system specs]
  • Tue, Jun 28 2011 8:01 PM In reply to
    • MosesN
    • Posts 79
    • Points 855
    Re: Exception: DIDReader::XraiseUnexpectedStreamStatus async file system error
    Bumping, just to make sure if anyone else has seen this problem.
  • Tue, Jun 28 2011 10:57 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    If you have any external monitoring IO connected, disable it by going into 1394 mode.
    Make sure you're outputting HDV and that you're in a 1080i project.  Make sure the deck is expecting HDV rather than SD.
    Specific details would help: project type, deck, OS version, MC version, etc.
  • Wed, Jun 29 2011 4:51 AM In reply to
    • MosesN
    • Posts 79
    • Points 855
    HBrock, your inquiry made me look at my system specs and while I was away itunes must've updated, I'm running MC 4.0.5, but my quicktime jumped to 7.6.6, and my OS to 10.6.6, I should be in QT 7.6.4 and OS 10.6.2.
    The weird thing is that I am able to export to HDV device from another sequence, the one I currently need to output is the one sequence crashing when it starts making the M2T file.
    I hope that my solution is the QT version fix, but I have a feeling the problem stems somewhere else and just happens to coincide timing wise.
    I am currently working abroad and for some reason I decided not to bring my install discs along with me, so I will not be making the OS & QT rollback anytime soon.
    Thank you for the help.
  • Mon, Aug 8 2011 6:02 PM In reply to
    • Jean Dunoyer
    • Watertown, MA
    • Posts 156
    • Points 2,015
    I am getting this error as a result of consolidating an hour-long clip.
    MacPro 2 X 2.4 GHz Quad-Core Intel Xeon 6GB 1066 MHz DDR3/Avid MC 5.0.4 OS 10.6.8 [view my complete system specs]
    DunoyerFilms.com
  • Mon, Aug 8 2011 9:10 PM In reply to
    • MosesN
    • Posts 79
    • Points 855
    I was able to fix tihis error by lifting the color correction effects from my sequence. Some of the color effects generated corrupted files.
    If you wish to simply know where your problem is, I suggest doing a video mixdown. The Mixdown should crash at the point of the corruption, and you can check at what exact point that is because the mixdown is saved up to the point of the crash. Go to the crash point (end of the mixdown clip), and figure out what effect OR clip is giving you the corruption back in your sequence. Replace it and try again.
    Let me know if this worked, I had a serious headache because of this error.
  • Mon, Aug 8 2011 10:01 PM In reply to
    • Jean Dunoyer
    • Watertown, MA
    • Posts 156
    • Points 2,015
    I am consolidating a clip, not a sequence.  It's an hour long show they digitized for me down in DC.  Does this mean I have to ask them to do it again?
    DunoyerFilms.com
  • Tue, Aug 9 2011 1:07 AM In reply to
    • MosesN
    • Posts 79
    • Points 855
    What resolution are you working on and how did they get that whole hour to you? In a drive I assume.
    Before contacting them I would re-import the clip into the Avid and try again.
    Also, as stated in above in the thread, check your system configuration as well to make sure that's not the issue. I can personally tell you that I am working abroad and don't have my installer discs, my quicktime updated to a version I shouldn't use, and besides that one time I had this issue with exporting to tape, I have not had any other problems.
    Hope this has helped.
  • Tue, Aug 9 2011 1:31 AM In reply to
    • Jean Dunoyer
    • Watertown, MA
    • Posts 156
    • Points 2,015
    It was a master tape which was digitized HD 1080i/59.94  DNxHD 220 X
    It was sent to me on a portable drive.
    DunoyerFilms.com
  • Tue, Aug 9 2011 1:53 AM In reply to
    • MosesN
    • Posts 79
    • Points 855
    Oh darn so you got MXF files. Have you tried the mixdown? Does it freeze in the same part always? There are is a procedure to fix corrupted files, I will send it over in a bit. Considering you are only working with one clip, this solution might help you
  • Tue, Aug 9 2011 2:08 AM In reply to
    • Jean Dunoyer
    • Watertown, MA
    • Posts 156
    • Points 2,015
    Have not tried the mixdown.  Dude!  I'm stoked you're hanging in there to help me out!
    DunoyerFilms.com
  • Tue, Aug 9 2011 2:21 AM In reply to
    • MosesN
    • Posts 79
    • Points 855
    Don't worry brother I'm here cutting watching me some Squidbillies. I'll be up.
  • Tue, Aug 9 2011 4:11 AM In reply to
    • MosesN
    • Posts 79
    • Points 855
    Try this.
    http://avid.force.com/pkb/LegacySearch?DocId=268209
  • Mon, Jan 28 2019 1:29 AM In reply to
    • YuliaStar
    • Joined on Sat, Jan 5 2019
    • Posts 3
    • Points 45
    2019, and I have the same problem. Niccceee
  • Thu, Mar 7 2019 2:39 PM In reply to
    • mnbkyle
    • Joined on Tue, Sep 15 2015
    • Minneapolis, MN
    • Posts 39
    • Points 460
    I'm getting a variation - Exception: DIDReader::XraiseUnexpectedStreamStatus async EOF error
    I get this while transcoding ama linked FS7 XAVC to DNxLB. it stops the transcode after a couple clips....
