Latest post Tue, Jun 21 2011 4:22 PM by dgresh. 2 replies.
  • Mon, Jun 20 2011 5:15 PM
    • dgresh
    • Philadelphia, PA
    • Posts 12
    • Points 140
    XDCAM AMA linking problem
    I've been trying to link to files shot on a Sony F800.  I transferred the files from the DVD media that came in from the field to my RAID storage, but when I try "Link to AMA Volume" Avid won't recognize the files.
    I was able to link to files from another F800 once before, and in comparing the two projects, I see the folder heirarchy is different.  On the project where everything wworked fine, I see these folders:
    Clip
    Component
    Edit
    General
    Sub
    UserData
    And these files:
    ALIAS.XML
    DISCMETA.XML
    INDEX.XML
    MEDIAPRO.XML
    SYSPRO.XML
    In the project that I cannot link to, I see these folders:
    CLPR
    CMPTR
    EDTR
    USERDATA
    and these files:
    ALIAS.BUP
    ALIAS.XML
    DISCINFO.BUP
    DISCINFO.XML
    DISCMETA.XML
    INDEX.BUP
    INDEX.XML
    SYSPRO.XML
    My system is MC Nitris DX Version 5.2, with AMA plugin Version 1.4 installed
    Any help appreciated!
    Media Composer 5.52 Nitris DX HP z4000 workstation, Win7 Rorke Data Galaxy HDX2 array Panasonic AJ HD1400 DVCProHD deck [view my complete system specs]
    Filed under: ,
  • Mon, Jun 20 2011 6:04 PM In reply to
    • Kristina
    • Joined on Sun, Nov 28 2010
    • Germany
    • Posts 462
    • Points 5,590
    Re: XDCAM AMA linking problem
    yes the folder structure in your working project is a regular structure for a ProfDisc made by PDW-F800.
    Do you have the original ProfDisk or what do you mean by "DVD"? The structure is definitely not coming from a original PDW-800 ProfDisc.
    Best regards,
    Kristina
    several z800 and xw8600 Nitris DX, MC v.5.5.3, Win XP Prof SP3, ISIS-5000 16TB with Force 10 Switch 10Gig, several MOG S1010 ingest servers, several EVS... [view my complete system specs]
  • Tue, Jun 21 2011 4:22 PM In reply to
    • dgresh
    • Philadelphia, PA
    • Posts 12
    • Points 140
    Thanks Kristina.  I think I got it sorted...
    I installed an updated driver for the PDW-U1 disc drive and now the folder structure is correct.  Weird.
