Latest post Thu, Jul 5 2018 4:07 PM by Schnittskunk. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Jun 16 2011 12:01 PM
    • Nnata
    • Joined on Tue, Jul 13 2010
    • Posts 1,026
    • Points 13,665
    Duplicating a clip in the timeline?
    A function I perform often in FCP is to optn drag a clip in the timeline to anywhere I want. Can I do this in Avid?
  • Thu, Jun 16 2011 12:13 PM In reply to
    Re: Duplicating a clip in the timeline?
    Timeline position indicator over the clip you want.
    T key to Mark the clip  I and O.
    Alt C to copy clip into your source monitor.
    Go where ever you want in the timeline, mark in (I key) and overwrite (B key) or insert (V key) edit the clip there.
    Repeat as required
  • Thu, Jun 16 2011 5:46 PM In reply to
    • Nnata
    • Posts 1,026
    • Points 13,665
    'Sigh'. Thanks for your response.
  • Thu, Jun 16 2011 6:17 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,315
    • Points 17,020
    Why the "sigh?" Much faster than any other editor I've used. With much more control.
    Chris
    MacPro 3.33Ghz 12 Core (Westmere, MacPro 5,1), 48Gb RAM, nVidia GeForce GTX 680, Intensity Pro (Desktop Video 10.4.3), OS X 10.12.2, MC 8.8.2 [view my complete system specs]
  • Thu, Jun 16 2011 6:21 PM In reply to
    The only thing that I don't like is that the file pastes only on the same track that
    it copied from.
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(390.77)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 2018.11 with Symphony Option on Dongle/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Thu, Jun 16 2011 7:16 PM In reply to
    • nigelad
    • London UK
    • Posts 520
    • Points 6,025
      Avid Certified User
    Change track patching before overwrite or insert and hey presto.
    ISIS 5500, MC 18.4 & PT 18.4 on Mac OS with BMD Mini-Monitors, an UltraStudio 4K and AJA T-taps. [view my complete system specs]
    • tchoupiboss
    • Joined on Tue, Jul 6 2010
    • Paris, FRANCE
    • Posts 22
    • Points 280
    Hey !
    You also can use the Red or Yellow arrows ("paste/replace" or "insert" mode) to select the clip(s) you want to duplicate.
    - Select the mode you want to use. (I have keyboard shortcuts for these very useful functions)
    - Select the clip(s)
    - Press Cmd C
    - Place the blue timeline indicator where you want to paste or insert the clip
    - Press Cmd V. The clip will be duplicated to the same track where it was.
    Yes... I know; Not as simple as FinalCut !
    MacPro Late 2013 - 3,5 GHz 6-Core Intel Xeon E5 - 32Gb memory - AMD FirePro D700 6144 Mo - MC 8.8.1 - Working fine :-) [view my complete system specs]
  • Thu, Jun 16 2011 7:18 PM In reply to
    sverkalo:
    it copied from.
    It only does that if you use CTRL+C for Copy and CTRL+V for Paste (as if you were using MSWord), if you ALT+C instead, it loads it into the Source monitor and you can patch it to any tracks you like, just as you would any other source clip.
  • Wed, Jul 4 2018 8:04 AM In reply to
    • pianohill
    • Joined on Wed, Jul 4 2018
    • Posts 1
    • Points 5
    Nnata:
    mac: SHIFT+ALT+COMMAND+CLICK/DRAG will duplicate the clip
    for PC i guess you just switch command for control key.
  • Thu, Jul 5 2018 4:07 PM In reply to
    • Schnittskunk
    • Joined on Tue, Sep 20 2011
    • Berlin, Germany
    • Posts 8
    • Points 90
    You can use the Segment Tool and then opt-drag the clip anywhere you want
    MacPro 5,1 12Core, 48GB RAM, OS X 10.12.6, MC 2018.5 MojoDX / MacBook Pro Retina 2015 2.8, 16GB RAM, OS X 10.12.6, MC 2018.5 [view my complete system specs]
