Latest post Wed, May 4 2011 5:15 PM by erik1185. 7 replies.
  • Tue, May 3 2011 12:48 PM
    • fkurz
    • Joined on Wed, Jan 23 2008
    • Posts 31
    • Points 380
    MC 5.0.3.9 - stereo-audio-mixdown error using crossfades
    Hello!
    I did a mix-down of a stereo-audio-track with cross-fades at start and end of one clip and got an incorrect result. As you can see on the attached image, the left channel of the mix-down seems to fade in and out smooth an correctly but the right channel has a hard cut in an and a not smooth fade out.
    Also when I playback the original stereo-track with the cross-fades, not the mix-down, it seems that left and right channel have slightly different audio levels during the fades.
    I can confirm this behavior also for the MC 5.0.3.8 and it occurs on two different machines, both are certified HP Z400 running win 7/64bit.
    Has anyone else encountered these errors?
    Regards
    Flo
    Avid MC 2018.2 symphony option HP Z820 Win 7 64Bit, SP 1 Mojo-DX Interface [view my complete system specs]
  • Tue, May 3 2011 12:55 PM In reply to
    Re: MC 5.0.3.9 - stereo-audio-mixdown error using crossfades
    fkurz:
    ...when I playback the original stereo-track with the cross-fades, not the mix-down, it seems that left and right channel have slightly different audio levels during the fades.
    In your audio project settings under the "effects" tab, make sure Dissolve midpoint attenuation is set for constant power, not linear.
  • Tue, May 3 2011 1:10 PM In reply to
    • fkurz
    • Posts 31
    • Points 380
    Larry, thanks for your relpy!
    I just checked the audio effects setting and it is set to "constant power". So that could not be the reason.
  • Wed, May 4 2011 11:48 AM In reply to
    This is a bug, and it's in 5.5.1 too.
    If you set the audio effects to linear, you get an even response on the left and right part of the stereo clip. If you set audio effects to constant power, then the constant power is only maintained on the left channel.
    I'll escalate.
  • Wed, May 4 2011 11:53 AM In reply to
    • fkurz
    • Posts 31
    • Points 380
    thanks a lot!
  • Wed, May 4 2011 12:03 PM In reply to
    Thank you. Good catch.
  • Wed, May 4 2011 4:46 PM In reply to
    Confirmed as a bug. Logged as UDevC00155998.
  • Wed, May 4 2011 5:15 PM In reply to
    • erik1185
    • USA
    • Posts 1,062
    • Points 13,080
    Job ter Burg:
    Awesome! I'v been complaining about this one since 5.0.x.
    Late 2013 MacBook Pro, 2.4 GHz Intel Core i5, 8 GB RAM, Intel Iris 1536 MB Graphics [view my complete system specs]
