Latest post Thu, Apr 21 2011 5:00 AM by ichosteve5494. 4 replies.
  • Thu, Mar 31 2011 6:42 AM
    How can select DNxHD Compression format on the column ot Metafuze 2.5?
    In version 2.2.5, transcode to DnxHD the the Compressionon column on the Group view. that could easily select the resolution. But version 2.5 is not available. the output preset of 2.5 version only had uncompressed resolution.
    and i had more than 100 red files, the 2.5 version need select  each transcode job manually for DNxHD Resolution.
    How can batch select DNxHD Compression format on the column on Metafuze 2.5?
    Steve Cho
  • Thu, Mar 31 2011 2:27 PM In reply to
    Re: How can select DNxHD Compression format on the column ot Metafuze 2.5?
    Select your transcodes.
    Click on the Create button in the Output preset window.
    [Optional] Name your preset, so you will be able to find it for a later use.
    Tweak your output settings (including compression).
    Voilà!
    The default output preset are read-only, so you need to create a new one in order to select the desired compression.
    Etienne Allard
    Engineer | P&S Creative Professional
    Avid
  • Fri, Apr 1 2011 2:38 AM In reply to
    Dear Etinne,
    If default output Preset read-only, how can create a compression preset?
    I
    can not find the option on the user guide or readme.
    P.S: i can create new preset on the Output preset window. But i don't renaming this created preset.
    Steve Cho
  • Fri, Apr 1 2011 2:36 PM In reply to
    Created preset are editable. So, if a new preset is created (its initial name will be something like "Copy (1) of 1080 50i (8 bits)" ), its Compression will be editable. Once the preset has been edited, just select the created preset in the "Output Preset" row of the Detail window (or column of the Group window).
    Some informations about the Output Preset can be found on page 43 of the user guide.
    Etienne Allard
    Avid
  • Thu, Apr 21 2011 5:00 AM In reply to
    Thanks your answer!!
    Steve Cho
