Latest post Thu, Mar 3 2011 2:05 AM by hbrock. 3 replies.
  • Tue, Mar 1 2011 7:29 PM
    • jaysonL
    • Dallas, TX
    • Posts 24
    • Points 345
    ameBaseStream::Connect failed to connect
    I had a clip that was acting like it might have trouble so I took the media offline and reimported from the original aaf and mxf media file (these are transcodes from R3D) I have been getting this error ever since.
    I can import the clip into another project and see it and play it fine.  However when I open that bin in my current project, I get this same error.
    Any ideas?
    Thanks, Jayson
    MC 5.03 on 10.6.3
    MC Meridian MC Adrenaline MC Nitris and Xpress Pro [view my complete system specs]
  • Wed, Mar 2 2011 9:05 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Re: ameBaseStream::Connect failed to connect
    Same resolution and frame rate in both projects?  Are you importing or dropping the MXF files in the Avid MediaFiles folder and linking to the AAF?
  • Wed, Mar 2 2011 3:16 PM In reply to
    • jaysonL
    • Dallas, TX
    • Posts 24
    • Points 345
    I am dropping the transcoded mxf files in the workspace, rebuilding the database and importing the aaf files into the project. they have the same resolution and frame rate.
    Jayson
  • Thu, Mar 3 2011 2:05 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    The workspace being the Avid MediaFiles folder?
    If the files play OK in a different project, you might want to try trashing the settings.  If they don't play properly in a different project, try remaking them from the original media.
