Finally upgraded my DV, Have a new Sony Nex Camera which shoots 1080i 50 Video in AVCHD Video. I have it in underwater housing and am very happy so far. Data Rate is 16690 kbps.
Cant Link to AMA, assume AMA doesnt work with these type of files, however im not fussed.
Im confused as to what is the best/ideal resolution to import into MC5 for outputting to Bluray and AVCHD movies (Short movies burnt to DVD disks) and without losing any quality.
Have used DNxHD 120 for test project and it looks good, obviously when import have several options, DNxHD 185 etc.
I have captured both and quality looks the same.
Any reason not to use DNxHD 185 or something else for that matter.
Hugh
South Australia
weakest link theory your avchd files are more compressed than either one of the avid settings so use the smaller one and it will be great
Tom Pearson
Sorry to hijack the thread, but I believe this could related to the original subject:
Is there a difference in quality between DNxHD 120 (raster size set to 1920x1080) and DNxHD-TR 120 (raster size set to 1440x1080). Visually I can't see any on the monitor.
... it always depends, whether you like to add VFX, titles, fotos etc. In this case I would always prefer full hd 1920x1080 50i, DNxHD185x 10bit color space due to extra graphic works, although you would use more hd space.
Just give it a try.
Is my understanding correct that the higher the DNxHD number (120, 185) the higher the bitrate (?) and therefore the higher the quality? What does the number values of DNxHD refer to? I've trying to get my head around Avid HD for a long time now
DNxHD-TR 120 means it is using 120 Mb/s (megabit) for a thin raster frame.
DNxHD 120 is 120 Mb/s for full raster of 1920 x 1080. Same data rate but larger frame size.
Meaning TR is more efficient since the data allocation is for HDV's thin raster of 1440x1080.
DQS
www.mpenyc.com
Thanks Dom.
I take it then there is no real visible quality difference between TR-120 and 120, other than the frame sizes which only Avid sees? Reason I'm asking is because I'm on a laptop-based system that performance wise handles HD sequences better at a thin raster settings than full raster. I wouldn't want to sacrifice quality
There is a difference. How visible? Probably barely. DNX TR allows you to allocate the same amount of data in a slightly smaller frame.
If your sequence are all the same raster size (1440) it should perform slightly better as there are less pixels to process.
This thread has been very useful but I was wondering if anyone could answer what is the best resolution that uses the least space to import GOPRO, AVCHD, and CANON 5D please? Dnx 120 and Dnx 185 x just uses up too much space!
Many Thanks,
Katie
Hi Katie,
The Avid storage calculator can help you figure out how much space a particular amount of a particular resolution will take up, and that can help you decide how to proceed:
http://www.avid.com/US/resources/avid-storage-calculator
ciao,Carl
That's great, this is very useful. Would it affect the quality hugely if I imported my GOPRO, AVCHD, and CANON 5D all at the XDCAM 50 resolution because that uses a lot less space?
kt
