Latest post Tue, Dec 21 2010 3:49 PM by slabross. 2 replies.
  • Thu, Dec 16 2010 9:27 PM
    Video HAL errors
    first off system specs in quick:
    Core i7 980x
    12 gb ddr3 memory
    quadro fx 4600
    win7 x64 Pro
    when importing any clip, it conforms, then i drag it in, the preview is blank, i try to apply an effect, playback and video hal error appears, shutsdown the program. ????????? drivers problem?
  • Fri, Dec 17 2010 4:36 PM In reply to
    • dermot
    • Vancouver, Canada
    • Posts 524
    • Points 6,245
    Re: Video HAL errors
    Possiably drivers....
    Did you use the Nvidia driver supplied in the drivers package?
    There's an Avid error log you can get to directly inside DS, maybe check it out and see if it gives you any more suggestions...
    8600 - 3700 - AJA 2Ke - u320 array - Dream Color [view my complete system specs]
  • Tue, Dec 21 2010 3:49 PM In reply to
    • slabross
    • Montreal, Quebec, Canada
    • Posts 938
    • Points 9,690
    • ! Avid Employee
    You can view the error logs also from Windows. Expand the Event Viewer and the Applications and Services Logs list, then select the Avid Event Log.  On the right panel, open the entries that are marked with an Error or Warning to verify what is wrong.
    You can also check the Windows Logs > System events in case this is more of a Windows specific issue, such as a driver fault or something else.
    Sylvain Labrosse
    Principal Expert | Services and Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    Create cases online now at  csportal.avid.com
    It's fast, easy and effective!
    We're Avid.  Learn more at www.avid.com
