Latest post Thu, Nov 14 2013 3:07 PM by GT. 15 replies.
  • Sat, Dec 4 2010 3:24 AM
    • NewBlueFX
    • Joined on Wed, Oct 27 2010
    • Posts 32
    • Points 620
    • Avid Authorized Developer - AVX
    Add a Running Timer to Your Video with Time Clock from NewBlueFX
    Add a running timer to a video using Time Clock from NewBlue Video Essentials IV.
  • Thu, Jun 14 2012 10:49 PM In reply to
    • Jeff Smith
    • Joined on Thu, Jun 14 2012
    • Posts 7
    • Points 85
    Re: Add a Running Timer to Your Video with Time Clock from NewBlueFX
    Anyone tried to drop newbluefx timer control on empty a/v track so it can span multiple video clips?  Can't seem to get the control to load on empty track.
    thanks
  • Fri, Jun 15 2012 12:20 AM In reply to
    Hi Jeff,
    Yes, you should absolutely be able to use Time Clock like you describe. What currently happens when you try to place it on an empty video track?
    Are you able to use it if you place it directly on a clip?
  • Sun, Jun 17 2012 11:51 AM In reply to
    • Jeff Smith
    • Posts 7
    • Points 85
    Thanks for the quick reply Marcus.  Yes - the effect works when placed directly on a clip; however, when applying to an empty track, it simply will not load.  The reason I am applying to an empty track is an attempt to apply the timer to multiple video clips so the timer counts down from beginning to end across the entire project.  Thanks - Jeff
  • Sun, Jun 17 2012 9:24 PM In reply to
    Jeff, when you say that it won't load, do you mean that you just can't see the time? Or, that you're not able to see the effect applied at all on your timeline?
    Also, can you please tell me what Media Composer version you are using, and is it on a Mac or PC?
  • Sun, Jun 17 2012 11:32 PM In reply to
    • Jeff Smith
    • Posts 7
    • Points 85
    Hi Marcus,
    I am using AVID Studio on PC and the effect simply won't "stick" to the empty A/V track when dragged onto it.  No problem dragging onto a track that already has video loaded on it whether it's a single clip or multiple clips.  The issue is that it has to be applied to each clip individually and there's no way to have it span all clips whith contiguous time from beginning to end.  I have see a tutorial that suggests what I am attempting can be done, but not enough detail in the tutorial to really determine if a specific media editor is needed to accomplish this task.
    Here's the link to the tutorial.
    http://www.youtube.com/watch?feature=player_embedded&v=Slns9XiI05o
    Jeff
  • Sun, Jun 17 2012 11:35 PM In reply to
    • Jeff Smith
    • Posts 7
    • Points 85
    Marcus,
    Doh - just realized you actually posted the video I referenced.  I guess you are definitely the person who can tell me how you accomplished this task.
    Jeff
  • Mon, Jun 18 2012 1:27 AM In reply to
    Try putting an add edit on the empty track. Avid (sometimes) ignores effects on an empty track. Yes, you could put an add edit at the very end.
    And if it works, (or not) let me know?
    thx
    JG
    Best,
    Jeff G
  • Mon, Jun 18 2012 1:56 AM In reply to
    • Jeff Smith
    • Posts 7
    • Points 85
    Thanks for the reply.  As best I can tell, there is no option to put an add/edit on a track in Avid Studio.  I suspect I am working with a tool that simply can't do what I want.  I am in the process of reviewing tools before buying one and want certain capability.  I suppose Avid Studio just can't do what I need.  Many thanks anyway.
    JES
  • Mon, Jun 18 2012 2:16 AM In reply to
    • Posts 10,018
    • Points 215,695
    Jeff Smith:
    Jeff,
    I think there are some wires crossed here.
    You are using Avid Studio - this is an Avid Media Composer Forum.
    Others are thinking that you are asking about Media Composer.
    You should move over to the STUDIO Forums and ask the question again.
    Regards,
    Douglas
    PS. you are not alone in making this mistake about forums!
  • Mon, Jun 18 2012 2:42 AM In reply to
    Okay, yes, that explains a lot. This forum is just for Avid Media Composer / Symphony so I assumed that's what you were using. No, there's no way to apply an effect to an empty track in Avid Studio.
    That being said, with Time Clock, what you can do is place a video clip (any video clip) on the top track that covers the amount of time that you need. Then apply Time Clock to that clip and make sure "Overlay" is checked. That top video will be keyed out and you will just see the timer applied to your video clips on the lower track.
  • Mon, Jun 18 2012 3:08 AM In reply to
    • Jeff Smith
    • Posts 7
    • Points 85
    Many thanks to all who commented.  Sorry for stirring up any confusion regarding which forum I should be on.  mea culpa ...Smile
  • Mon, Jun 18 2012 3:22 AM In reply to
    • Jeff Smith
    • Posts 7
    • Points 85
    Thanks Marcus - that is a great workaround.  I tried it successfully.
  • Fri, Sep 20 2013 11:52 AM In reply to
    • Keith R
    • Joined on Fri, Jun 8 2012
    • Posts 286
    • Points 3,370
    Hello Douglas Hopefully you are planning more Tutorials on NewBlueFX ...!!! Idea
  • Thu, Nov 14 2013 12:11 PM In reply to
    My apologies if I am doing something wrong but I have dowloaded and unzipped the file and then saved them to the Avid Studio plugins (and also Red Giant) folders but when I open the editor on a chosen video clip I cannot see or find the clock files.
    Any (pritable!) suggestions please.
    Colin
