Latest post Wed, Oct 20 2010 8:31 PM by whispered_threat. 3 replies.
  • Mon, Oct 18 2010 10:45 PM
    Media Composer 5.0.3 OS X Failing to launch
    I've been running the trial of Media Composer 5.0.3 for the past 2 weeks without any problems
    For some reason today when I launched the program when boot up got to "Initializing AVID Media Access Volume Manager" It froze/crashed and I had to force quit.
    Heres what I've tried:
    1. Reboot
    2. Eject / Disconnect External HD, Reboot
    3. Uninstall / Reinstall Media Composer then 1 and 2 again
    4. Uninstall Media composer then Pro Tools Reinstall protools then Reinstall Media Composer / Repeat above steps
    5. Located and moved Avid MediaFiles Folders on all drives/partitions tried above again
    6. none of this has done anything, when the program is lauched it proceeds normally through I/O Initialization, Plugin Initialization etc., but never gets past Initializing Media Access Volume Manager...
    I've searched and haven't managed to locate anything pertaining to this issue
    any suggestions would be appreciated
    thanks
    Macbook Pro 2.4 GHz Intel Core 2 Duo 4 GB 667 MHz DDR2 SDRAM OS X 10.6.4 Pro Tools LE 8.0.4 MBox 2 / 003 Factory Media Composer 5.0.3 Trial ... [view my complete system specs]
  • Tue, Oct 19 2010 10:30 AM In reply to
    Re: Media Composer 5.0.3 OS X Failing to launch
    hi,
    try to move the database files (msmFMID.pmr and msmMMOB.mdb)
    located : Applications/Avid Media Composer/SupportingFiles/Avid_MediaFiles/
    say me if that good !!
  • Wed, Oct 20 2010 12:27 AM In reply to
    This appears to have worked!!
    I was able to launch the program successfully
    thank you very much / merci beaucoup
    hopefully it continues to work properly
  • Wed, Oct 20 2010 8:31 PM In reply to
    So I launched Media Composer again today and.....
    It failied to launch again :( apparently the database files were not the problem.
    however I found the cause of the crash: when I disabled wifi ie: turn airport off, the program launched without a hitch.
    I tested this theory relaunching the program several times with airport on: it failed to launch every time, airport off: launched without a problem each time.
    although this is obviously not optimal it is an acceptable workaround.
