Latest post Thu, Sep 16 2010 2:57 PM by Steve Sidoruk. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Sep 15 2010 7:33 PM
    • Steve Sidoruk
    • Cheshire, CT USA
    • Posts 68
    • Points 1,055
    Import .avi file from Nikon DSLR in MC5?
    Does anyone have experience with importing .avi files from Nikon D90 DSLR?  I managed to get clips imported, but couldn't do any effects with them.  Indicated 0 frames available either side of cut.
    Mediainfo tells me .avi video is: 21.5 Mbps, 1280x720, 24.000 FPS, M-JPEG and
    audio: 178.4 Kbps, 16 bits, 1 channel, PCM.
    Win 10 64-bit Intel MBoard DX58SO2 Extreme Series; Intel Core i7 CPU, 3.07 GHz; 32 GB RAM; NVIDIA QUADRO FX 1700, PCIE; Readyboost 16 GB; MC 8.5.2; Matrox... [view my complete system specs]
    Filed under: , ,
  • Wed, Sep 15 2010 10:50 PM In reply to
    Re: Import .avi file from Nikon DSLR in MC5?
    Did you tried to Link by AMA and transcode?
    Desktop PC
    3 Heads Digital Films
  • Wed, Sep 15 2010 11:30 PM In reply to
    Steve Sidoruk:
    ...but couldn't do any effects with them.  Indicated 0 frames available either side of cut.
    Steve, in order to do transition effects between clips, you must allow "handles" - footage frames beyond the mark in and the mark out that are at least equal in duration to the duration of the effect itself. So, for example, if you want a 30 frame dissolve between two clips, your out mark must be at least 30 frames back from the end frame of clip 1, and the in mark at least 30 frames in from the start frame of clip 2.
  • Wed, Sep 15 2010 11:39 PM In reply to
    • Posts 10,202
    • Points 218,050
    Steve,
    As Larry says........ It is a question of Handles.
    Here is a more detailed explanation of Handles.
    Regards,
    Douglas
  • Thu, Sep 16 2010 12:53 AM In reply to
    • Steve Sidoruk
    • Cheshire, CT USA
    • Posts 68
    • Points 1,055
    Thanks for the help with handles.  I'm still not sure on the import - as I try different import settings, I'm getting strange results, such as, last frame of each clip is narrower than 16:9.
    Could it be that .avi files from a Nikon DSLR aren't standard?
  • Thu, Sep 16 2010 1:09 AM In reply to
    You have different aspect ratio choices in the options section of the import tool.
  • Thu, Sep 16 2010 2:57 PM In reply to
    • Steve Sidoruk
    • Cheshire, CT USA
    • Posts 68
    • Points 1,055
    Yes, but not clear which are correct settings to use - .avi clips from Nikon D90 are HD 720 16x9
    Mediainfo shows -
    VIDEO: 21.5 Mbps, 1280x720, 24.000 FPS, M-JPEG
    AUDIO: 178.4 Kbps, 16 bits, 1 channel, PCM
    I have tried different settings and some create a dimensionally smaller last frame.  Also not sure which setting will give best quality?
