Latest post Thu, Apr 21 2011 9:43 AM by Geoffs. 135 replies.
Page 6 of 10 (136 items) « First ... < Previous 4 5 6 7 8 Next > ... Last »
  • Sat, Sep 11 2010 1:59 AM In reply to
    Re: MC5 Bin Memory - Excessive?
    I can confirm the following errors when doing rapid trimming actions on a 90 minute timeline.
    AMA transcoded to DNX36. Mxo2 mini - HDMI 1080 out.
    Exception: std: exception, what:std::bad alloc
    and
    OUT OF MEMORY
    MC 8.8.2 OSX 10.12.3 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Sat, Sep 11 2010 2:09 AM In reply to
    James, if you disconnect the MXO2 mini and run soft only, do you still get the same errors? I'm trying to establish if there's a strong enough correlation between the memory errors and using the I/O hardware to warrant escalating this specific situation, since the memory issue itself is already escalated.
  • Sat, Sep 11 2010 2:28 AM In reply to
    • mjc
    • Los Angeles, CA
    • Posts 146
    • Points 1,745
    How many of you that are experiencing the memory crashes are using Sapphire plug-ins?  I'm trying to discover any pattern in my workflow here.  Thanks!
    Nitris DX Symphony Option / MC 7.0.4 | Mac OS X 10.8.5, Dual 3.2 GHz Quad-Core Intel Xeon MacPro, 10GB RAM | Facilis Terrablock 24D [view my complete system specs]
  • Sun, Sep 12 2010 9:37 PM In reply to
    • Howard
    • Joined on Fri, Mar 23 2007
    • Auckland, New Zealand
    • Posts 116
    • Points 1,585
    I am still having numerous out of memory issues on several workstations on v5.0.3.1. I can't afford to update to v 5.0.3.2 due to high production activity especially if it makes no difference.
    All are on MacPros, some of them brand new and two on iMacs.
    It's happening on Matrox, Analogue and SDI Mojo and Adrenaline.
    It happens on the iMacs without any external monitoring/Mojo device attached and sequences have minimal effects...some none at all. There is nothing specific that causes the crashes.
    HPZ400, 16GBRam. MCv8.3.1 [view my complete system specs]
    Howard Kramer
    Avid Editor / System Support Engineer
    AV Intelligence - Auckland, New Zealand
  • Tue, Sep 14 2010 1:13 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 491
    • Points 5,905
    Do we know if Avid are on the case here?
    Media Composer 2018.9 MacPro 6 core - 32 GB RAM - OS:10.13.6 3.33Ghz iMacs, Macbook Pros. BM, AJA, Matrox After Effects, etc [view my complete system specs]
    @jaketheeditor
  • Tue, Sep 14 2010 1:23 PM In reply to
    Yes, Avid is aware of this...the memory leak is already in escalation and being worked on, but at this point there is not enough reliable replication to indicate that the I/O hardware is directly related to it, as well as other factors (like Sapphire) possibly being suspect as well.
  • Tue, Sep 14 2010 1:33 PM In reply to
    • jakeheat
    • Posts 491
    • Points 5,905
    Thanks Larry, but just so Avid know, I don't have Sapphire on my system, and my timeline contains no effects (I'm just sync pulling) but still I have to restart once an hour when I have my MX02 box enabled.
    @jaketheeditor
  • Thu, Sep 23 2010 11:44 PM In reply to
    • Howard
    • Posts 116
    • Points 1,585
    Larry Rubin:
    Hi Larry...any further info from Avid on this problem yet? The only comment I have seen is the price increase!!
    Several clients are requesting roll-backs to v4 for editing workstations but having one v5 for an AMA ingest workstation. Sounds sensible but, if there is a imminent fix to v5 then I might just wait.
    Howard Kramer
  • Fri, Sep 24 2010 12:05 AM In reply to
    Nothing further yet.
  • Fri, Sep 24 2010 3:23 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,320
    • Points 17,065
    We just rolled back to 4.x on our Fox episodic because of issues with 5. This memory leak is disastrous.
    Chris
    MacPro 3.33Ghz 12 Core (Westmere, MacPro 5,1), 48Gb RAM, nVidia GeForce GTX 680, Intensity Pro (Desktop Video 10.4.3), OS X 10.13.6, MC 2018.12 [view my complete system specs]
  • Sat, Oct 2 2010 12:50 PM In reply to
    • Euchrow
    • Joined on Sat, Apr 15 2006
    • Brussels, Belgium
    • Posts 266
    • Points 3,490
    James@Seamless:
    and
    OUT OF MEMORY
    I'm having the same issues here, but on a software-only system. So 5.0.3 on osx 10.6.4. Working on a 130' feature film, 24p.
    I've imported subtitles with the Sub Cap effect, and the out of memory message pops up when I start correcting some of the subtitles. Like every 5-10 corrections.
    Annoying, but at least the system still allows you to save...
    Symphony 8.3 on Mac Pro Westmere 3.33Ghz 6 core, 48Gb Ram, Radeon 5770, Yosemite 10.10.1, Matrox MXO2 Mini 4.5 - MC 8.3 on MacBook Pro Retina 2.6 GHz,... [view my complete system specs]
    • Euchrow
    • Brussels, Belgium
    • Posts 266
    • Points 3,490
    James@Seamless:
    and
    OUT OF MEMORY
  • Tue, Oct 26 2010 10:48 AM In reply to
    • ChrisH
    • Joined on Thu, Sep 4 2008
    • Posts 112
    • Points 1,395
    Patch 5.03.5 now. Still nothing in the README which states that the issue has been fixed.
    This has been going on for months, is a serious problem and affects many. What's going on? Falling from grace.
    Work: Freelance, so usually a recent-ish Media Composer and ISIS/Unity Home: MC8.x, OS 10.10.5, 15.4" Macbook Pro, 2.8GHz Intel Core i7, Flash HDD... [view my complete system specs]
  • Tue, Oct 26 2010 12:44 PM In reply to
    I have just requested an update on this issue. I'll let you know if and when I hear something.
  • Wed, Oct 27 2010 10:17 AM In reply to
    I'm having the same issues here...
    I hope that there is an update that will come soon...
