Latest post Fri, Jun 18 2010 11:29 AM by Roland Achini. 4 replies.
  • Mon, Jun 7 2010 5:05 PM
    Make a sequence of sequences
    In Liquid, I often created short sequences and completely edited each one, then strung these together to form a single final sequence.  This worked very well, except each short sequence carried with it, into the final sequence, a very long tail of black filler.  This tail, of course, had to be deleted which needed to be carefully done, thereby being a nuisance.  If a similar procedure of "Seq of Seqs" is created in MC are there any quirks such as this?  (I am traveling and am unable to test this for myself.)  Thanks for any info.
    Intel Core2Duo 6400@2.13 GHz, Asus P5W DH DLX, 2GB Ram, XP Pro SP3, MC5.0.3.2, QT V7.6.6, AL V7.2, Sapphire Radeon 4750 512 MB PCI-x, Pinnacle 710-USB... [view my complete system specs]
  • Mon, Jun 7 2010 5:13 PM In reply to
    • AKA Dave
    • Joined on Mon, Dec 3 2007
    • Raleigh, NC
    • Posts 227
    • Points 2,735
    Re: Make a sequence of sequences
    In MC you can drag any sequence into the source monitor and use it as you would any other clip.  Set your ins and outs and edit it into your "sequence of sequences" and you're good to go.
    Dave
    MC 8.4.0 with Symphony Option. 27 Inch iMac. 3.5 GHz i7, 16GB RAM, NVIDIA GeForce GTX 780M 4096 MB, OS X 10.10.3 - MacBook Air i5 4GB RAM [view my complete system specs]
    You can load any Sequence into the Source monitor, Mark In/Outs and activate tracks just as you would for any other Source.  Then you can cut it into whichever "Master" sequence you like.
  • Tue, Jun 15 2010 7:47 PM In reply to
    Thanks for the help, guys.  You make my problems very easy to overcome.  Apreciate your help very much.
  • Fri, Jun 18 2010 11:29 AM In reply to
    The very long tail of black filler in Liquid can be avoided by setting an Out-Mark at the end of the sequences.
    MB: ASUS P6TD Deluxe, ATX, Intel X58, QPI 6.4GT/s, Intel LGA1366, 6xDDR3 1600MHz, PCI-E V2.0, On-board Soundkarte. CP: Intel Core i7 920 (2.66 GHz) Quad... [view my complete system specs]
