Latest post Thu, Mar 14 2019 10:50 PM by editgeezer. 14 replies.
Page 1 of 1 (15 items)
  • Wed, May 12 2010 11:36 PM
    • Hrubyink
    • Joined on Fri, Mar 31 2006
    • Posts 4
    • Points 65
    Applying Transitions/FX to multiple clips
    I know how to apply... say, a dissolve to multiple clips, but is there a way to apply other effects to multiple clips in the timeline?
    Example: I produced a three camera LIVE event that will need to be edited using MULTI-CAM. One of my camera operators forgot to both white balance and set frame aspect to match the other cameras (My fault for not checking)  After multi-caming the project, I've had to place both the matte effect and color correction icons over EVERY CLIP FOR THAT CAMERA in the timeline.
    Is there a faster way? If it's in the manual I haven't seen it (except for setting In and out, apply all, skip existing transitions, etc.) or can't find it.
    Thanks for any help you can provide.
  • Wed, May 12 2010 11:43 PM In reply to
    Re: Applying Transitions/FX to multiple clips
    Select the clips you want by lasso and Ctrl+ or Alt+ Double Click on the effect you want.
    Desktop PC
    3 Heads Digital Films
  • Mon, Mar 11 2019 8:57 PM In reply to
    why can´t I apply a dissolve to multiple clips using the Quick Transition(QT) button in version 2018.11? - When pressing the QT button I just hear the error sound. I´ve marked the in and out points on several clips on the timeline and then when I press the QT button the error sound appears. I can apply QT on a single clip but not on multiple clips.
    Best regards,
    Masse
  • Mon, Mar 11 2019 9:14 PM In reply to
    Can you post a screen shot of the area on your sequence where the QT isn't working? It might help to see what's going on.
  • Tue, Mar 12 2019 5:23 PM In reply to
    thanx for replying!
    Here is a screenshot of the timeline - I want to apply a dissolve to multiple clips on V3 - setting in and out points - pressing the QT button - getting audio error message. I can apply a dissolve to a single clip but not to multiple clips.
    Best regards,
    Masse
  • Tue, Mar 12 2019 5:58 PM In reply to
    Hi Masse,
    I can see two problems:
    1. The edits you have marked are on a track that is not turned on/active. The track has to be turned on for dissolves across in/out to work.
    2. It looks like you have also selected the clips, which may be confusing the system about what you want to do to them. Turn off red/yellow arrow segment mode.
    In addition to both of those, there's a check box on the QT dialog box that must be turned on for the in/out to work.
    I hope that helps!
  • Tue, Mar 12 2019 11:58 PM In reply to
    thanx again for helping me out!
    Now I´ve got it working, I did all the things you told me to do but the QT still didn´t accept.
    ...then I realized a real newbie fault, I forgot to place the marker right between two clips (not on a clip) on the track v3...
    So with your guidance and me giving myself a wake up call made it!
    Really appreciate your help!
    Masse
  • Wed, Mar 13 2019 7:05 AM In reply to
    You're welcome! I'm glad you got it figured out!
  • Thu, Mar 14 2019 4:57 PM In reply to
    Hi again,
    https://www.youtube.com/watch?v=eTDFDQVZSnY&t=12s
    check this video out (1.00 min), he can apply a dissolve on multiple clips without having the marker between clips - that doesn´t work for me. Is it a glitch?
  • Thu, Mar 14 2019 6:21 PM In reply to
    • Posts 10,152
    • Points 217,295
    editgeezer:
    Hi again,
    Are you still on 2018.11 and what OS exactly?   Want to try but dont want to do it in the wrong enviroment.
  • Thu, Mar 14 2019 7:43 PM In reply to
    editgeezer:
    How far are you from the edit point when you hit the QT button?
    Because I am a nerd, I just tested it out on my system. When I'm 100 frames from the nearest edit point and hit the QT button I just get the Windows error sound. If I am 90 frames from the nearest edit point and hit the QT button I get the QT dialog and the nearest edit point is highlighted.
    Maybe you're not close enough?
  • Thu, Mar 14 2019 10:31 PM In reply to
    Still on 2018.11 and on a Mac OS High Sierra, Imac 5k late 2014.
    /Masse
  • Thu, Mar 14 2019 10:42 PM In reply to
    Yes, looks like this is the answer - I´m in a 30 fps project and get the same result as you - good solid nerd investigation!
  • Thu, Mar 14 2019 10:45 PM In reply to
    editgeezer:
    Yay! This makes me so happy!
  • Thu, Mar 14 2019 10:50 PM In reply to
    LOL good work Sherlock!
    camoscato:
    editgeezer:
