Latest post Mon, May 10 2010 3:50 PM by Henk. 4 replies.
  • Sun, May 9 2010 4:30 PM
    • Wil
    • Joined on Mon, Feb 19 2007
    • Eindhoven, The Netherlands
    • Posts 156
    • Points 1,990
    Angry [:@] Activation MC4 after installation via internet failed
    Via the video community I have read that when MC fails to activate I should contact you or BLKDOG.
    I have bought the update from Liquid edition towards MC 4 and have installed the program.
    First I have tried to registrate and activate via the link in the program however I get an error message.
    Than I have tried another option via the internet but I need than an AVID Machine ID which I do not have or should I generatie this somewere?
    Never the less, I have registrate my program already via the internet  with the hope an activation code will be sent but without success.
    Pleas, can somebody guide me what to do?
    Thanks in advance,
    Kind regards,
    Wil Vermeesch
    Win 10-64 BIT; NVIDEA K4000;32GB. AVID MC 8.6.3 Plus IMac I7; 16GB [view my complete system specs]
  • Sun, May 9 2010 4:53 PM In reply to
    Re: Activation MC4 after installation via internet failed
    Wil:
    If you purchased the box set MC 4 upgrade, the system ID number will be printed on labels attached to your paperwork. If you still can't find it, contact Avid Customer Advocate Marianna and be sure to include copies of your purchase invoice.
  • Sun, May 9 2010 5:20 PM In reply to
    • Wil
    • Posts 156
    • Points 1,990
    Hi Larry,
    thanks for your reply but it's correct I have the serial number and system ID but activation via the internet faild.
    regards,
    Wil
  • Sun, May 9 2010 5:28 PM In reply to
    OK, then email Marianna and be sure to include your system ID number. She can help you.
  • Mon, May 10 2010 3:50 PM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Is there still a problem ??
    I try to register when I run MC from the toolbar (Special/Register your Software/ but when ik click on it the webpage can not be opened:
    Server Error/404 - File directory not found / The resource you are looking for might have been remover, had its name changed, or is temporarily unavailable.
    UPDATE
    Tried it also from the Avid website and there it worked..but Pushed after sending the send button again and it was possible to register it 2 times, so I recieved 2 Registration ID numbers..
    Henk
    Recom Powerstation black with Recom Pro Engine M850 Power/ Processor Intel Core i7 920,s1366 2,66Mhz QPI/ Memory = 2 x 3 x 2Gb (total 12Gb)/ 2 HD 750Gb... [view my complete system specs]
