Latest post Thu, Jun 23 2011 8:51 PM by haukez. 77 replies.
Page 1 of 6 (78 items) 1 2 3 4 5 Next > ... Last »
  • Thu, Apr 29 2010 10:57 PM
    Canon 5D workflow
    I just perused past posts but not really sure of this workflow or if it's going to be a major pain.
    I am shooting 1080/24p and want to know what the workflow is.  We are also shooting sync sound separately so I know we're going to have to sync to a clapper and not TC.  But what is the workflow for importing and ultimately using this as our online/export?
    -peter
    Mac Pro 2 X 2.8 GHz Quad-Core Intel Xeon Mac OS El Capitan 16gigs memory Nvidia GeForce GTX 980 4096mb [view my complete system specs]
  • Fri, Apr 30 2010 3:19 PM In reply to
    Re: Canon 5D workflow
    Use a 1080p/23.976 project.  You'll sync the audio based on inpoints, since, as you said, TC is not an option with the Canon.
    Other than that, it's normal editing.
  • Fri, Apr 30 2010 7:38 PM In reply to
    • pianoman72
    • Joined on Thu, Feb 9 2006
    • Dallas, TX
    • Posts 515
    • Points 5,920
    I would also recommend transcoding to DNxHD in MPEG Streamclip before importing your clips into Avid.  Try a test doing it this way versus importing the movies directly and make sure you don't see any color/gamma shift that might cause a problem.
    Media Composer 8.3.1, OSX 10.9.5 [view my complete system specs]
  • Fri, Apr 30 2010 9:33 PM In reply to
    On a sidenote, you may want to check out this utility:
    http://www.videotoolshed.com/product/42/qtchange/2
  • Fri, Apr 30 2010 9:39 PM In reply to
    • pianoman72
    • Dallas, TX
    • Posts 515
    • Points 5,920
    That's neat!  I'm so glad the new 5d Mk II firmware was released so we can shoot in 23.98 now...
  • Fri, Apr 30 2010 10:35 PM In reply to
    • kellyv
    • Posts 413
    • Points 4,840
    pianoman72:
    Do you find that it is quicker than directly importing into the Avid? Or is the thought to use it as an app that can work in the background?
    From what I have read, 5.0 will elimate this process as it can work with h264 natively. Nice.
    Late 2013 MacBook Pro 2.6 GHz Retina 15" with 2 TB Displays OSX El Capitan 10.11.3. Media Composer 8.5. BM Ultra Studio Mini Monitor. BM Desktop Video... [view my complete system specs]
    Editor
    • kellyv
    • Posts 413
    • Points 4,840
    pianoman72:
    Editor
  • Mon, May 3 2010 6:41 PM In reply to
    • pianoman72
    • Dallas, TX
    • Posts 515
    • Points 5,920
    It is an extra step that adds time, but you will be able to "fast import" so at least it's not doubling the wait.
  • Fri, May 7 2010 7:34 PM In reply to
    Footage was shot at 1080/24p- should I transcode to DNxHD at 709 or RGB levels?  Also, should I toggle to 1080p/23.976 DNxHD 115 or leave it at 1080i/59.94?
    thanks
  • Sat, May 8 2010 12:44 PM In reply to
    • MichaelPaine
    • Joined on Fri, Oct 5 2007
    • Alta, Finnmark, Norway
    • Posts 77
    • Points 1,005
    kellyv:
    I From what I have read, 5.0 will elimate this process as it can work with h264 natively. Nice.
    When will this be advantageous? Won't there still be excessive rendering times, even though we can access H.264 through AMA?
    Won't transcoding to an intermediate codec still make editing much smoother? If editing H.264 natively in AMC 5 is anything like editing H.264 in FCP, I'd rather pass. Thoughts?
    #1: Four HP xw4300, 3GB RAM - 3,6 GHz Dual-Core, Windows XP Pro, Media Composer 3.1.3.13 w/Mojo DNA, QuickTime 7.5.5, NVIDIA Quadro FX1400 - 128MB - driver... [view my complete system specs]
    Filed under: , ,
  • Fri, Jul 9 2010 3:38 PM In reply to
    • klipperklaus
    • Joined on Sun, Nov 19 2006
    • Copenhagen, Lima & London
    • Posts 18
    • Points 260
    Hey there,
    I have gone back to Leopard and the MC3 from the MC5 because my machine (see specs below ) wasnt stable with linking to material shot on Canon D7 thorugh the AMA.
    I am writing to hear if the only reason to transcode before importing into AVID is only a matter of faster import?
    We are planning to transcode/or directly import into AVID for offline DNxHD 36 and then Re-import for the ONLINE grade DNxHD 175 (X).
    But is there any other workflows that are better - higher quality, my machine doesnt have higher options than DNxHD175 (and what is the difference between 175 and 175 X)? And if there is a different way to do this, what is the workflow to get back to the native files for the online, without losing quality?
    I did a test transcoding the Canon D7 files with mpeg streamclip and compared the importing time into AVID.
    For a 17 second clip, it was 20 second faster on the import on the transcoded file compared with the original, but I didnt win much time, because it took approximately 20 seconds to transcode the nativefile to DNxHD36 in mpeg-streamclip.
    Best,
    Klaus
    Machine Specs:
    Model Name: MacBook Pro 15"
      Model Identifier: MacBookPro2,2
      Processor Name: Intel Core 2 Duo
      Processor Speed: 2.33 GHz
      Number Of Processors: 1
      Total Number Of Cores: 2
      L2 Cache: 4 MB
      Memory: 2 GB
      Bus Speed: 667 MHz
      Boot ROM Version: MBP22.00A5.B01
    Mac Book Pro, Mac Pro. Avid Media Composer. [view my complete system specs]
  • Fri, Jul 9 2010 3:47 PM In reply to
    The advantages to MPEG Streamclip is that you can shorten import times and you can do so without using the resources of the Avid.  Use another machine to transcode, then import in the Avid in bunches.  Heck, I have even ran MPEG Streamclip on the Avid and imported as I went.  At least with the downtime between imports you can log clips and pull selects.  if you directly import, you can't do anything until all the clips are done.
    I have also started using a freeware program called QTChange which will add a TC track to your clips and create an ALE which you can batch from.  You might want to check that out.
    And the difference between 175 and 175x is that all "x" resolutions are 10-bit.
  • Fri, Jul 9 2010 4:15 PM In reply to
    My is my workflow in this thread.
    I use Sorenson Squeeze because I am able to convert 2-3 H.264 files to DNxHD at the same time. It can also be done outside of my Avid application.
  • Fri, Jul 23 2010 9:19 PM In reply to
    • Marcus
    • Joined on Thu, Jul 8 2010
    • Munich
    • Posts 4
    • Points 60
    Hi Kevin,
    one question: Do you import the transcoded clips with the import function or as an ama file?
  • Sat, Jul 24 2010 2:37 AM In reply to
    • mmcapper
    • Posts 5
    • Points 75
    Hi Pianoman72. Why do you recommend transcoding to DNxHD ? Why not just use AMA? I've done both for projects on my side. The AMA is a bit weird with the QT media. But its almost worth the time savings. What is your experiences with this?
