Latest post Fri, Mar 26 2010 12:16 PM by Larry Rubin. 17 replies.
  • Thu, Mar 25 2010 3:52 PM
    • lasssman
    • Joined on Sun, Feb 7 2010
    • Toronto, Canada
    • Posts 103
    • Points 1,575
    Hardware - changing memory
    Yesterday I increased the memory in my computer. Do I have to do anything to MC to make sure it "knows" the change has happened?
    Intel Core 2 Quad Q6700 @ 3.3 GHz, Intel D975XBX2 MoBo, 160 GB Sata II system drive, 1 Tb Raid 5 media and render drives, 8 GB DDR2-800 mem, Windows 7... [view my complete system specs]
    Guy
    _______________
    lasss productions
  • Thu, Mar 25 2010 3:59 PM In reply to
    Re: Hardware - changing memory
    Your specs list Win 7/64-bit.  A 64-bit OS will automatically recognize the RAM.  Note: Win7 is not officially supported at this time.  But, it'll rock with more RAM.  6-8GB's works best depending on the MoBo.
    (wwld)
  • Thu, Mar 25 2010 7:50 PM In reply to
    What I have done all the times I upgraded the memory, for example from 4 to 8G at my desktop and from 2 to 3 at the laptop, it was to do a clean install of the OS after a memory upgrade.
    And as Randall says, MC with 8G on a 64bit OS is something else.
    I anticipate to the day that MC will run at 64bit.
    Then we will be talking for something else again.
    Desktop PC
    3 Heads Digital Films
  • Thu, Mar 25 2010 8:20 PM In reply to
    sverkalo:
    Doing a clean OS install is a good idea from time to time. But don't see why it would be a good idea to after changing memory in particular?
  • Thu, Mar 25 2010 8:29 PM In reply to
    Because it's a significant change of the system.
    It's just what I have done so far.
    Desktop PC
  • Thu, Mar 25 2010 11:28 PM In reply to
    • lasssman
    • Toronto, Canada
    • Posts 103
    • Points 1,575
    My Windows system shows 8 GB - but  the MC Hardware tool shows only 4 GB. So while Windows has recognized the change, apparently MC has not.
    There must be a way to refresh the MC hardware - or is it in an ini file that has to be modified?
    Guy
    _______________
    lasss productions
  • Thu, Mar 25 2010 11:48 PM In reply to
    MC uses a maximum of 4 GB ram to run the program in Vista flavors. I doubt that will change whenever 7 is qualified. Windows XP Pro maxs at just under 3 GB. Here are the system requirements for Media Composer.
  • Fri, Mar 26 2010 12:17 AM In reply to
    • lasssman
    • Toronto, Canada
    • Posts 103
    • Points 1,575
    Does that mean that if I have an 8GB machine MC will not use the extra (above 4GB)?
    Guy
    _______________
    lasss productions
  • Fri, Mar 26 2010 12:23 AM In reply to
    Correct.  MC is still a 32-bit app.  Even running in a 64-bit OS, 32-bit apps can only address 4GB's of RAM, regardless of how much is installed.  But, that's still approx twice the RAM that would be available to MC running in a 32-bit OS.
    (wwld)
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    That is currently the case....yes.
  • Fri, Mar 26 2010 1:51 AM In reply to
    BLKDOG:
    Sounds like this may be changing....soon !!  ??
    Dell m4600, i7-2820qm, nvidia Quadro 2000M, driver 8.17.12.6696, 16gRam, Win7Pro [view my complete system specs]
    • lasssman
    • Toronto, Canada
    • Posts 103
    • Points 1,575
    Ok ... so by installing 8 GB I get the full 4GB for MC, plus room for the OS, plus room for additional apps ....? e.g SF Pro?
    Guy
    _______________
    lasss productions
  • Fri, Mar 26 2010 2:13 AM In reply to
    • sam the sham
    • Apple Valley, Ca
    • Posts 924
    • Points 11,790
    BobbyMurcerFan:
    sverkalo:
    Sound advice, But (please correct me if I'm wrong) don't forget to DE-activate MC before you install clean OS. Confused
    MC 6.0.3.1 thank you very much, FCP X v.10.2.3, MAC Pro, 2 @ Intel Quad-Core Xeon 2.4 GHz,(Westmere),12gb 1066mhz DDR3 ram, ATI RadeonHD 5870 1GB. 3@ 1TB... [view my complete system specs]
  • Fri, Mar 26 2010 5:08 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    lasssman:
    Guy, I am rendering in AE and editing in Media Composer at the same time, multitasking SF Pro will be a piece of cake
    Tomas
  • Fri, Mar 26 2010 11:38 AM In reply to
    lasssman:
    That's exactly right.
