Latest post Tue, May 2 2017 6:37 PM by chuckkahn. 3 replies.
  • Wed, Jan 20 2010 3:20 PM
    • john_john
    • Joined on Wed, Jan 20 2010
    • Posts 1
    • Points 15
    Open an STL(EBU) file in avid
    Hello everyone,
    I have a serious problem moving from my old mechanism(which works with PAC and STL files) to Avid.
    Can i open an STL(EBU) file in avid?(with the original font and locations from the STL file)
    Can i convert an STL(EBU) file to AVB? or at least convert the STL into XML file and then open it in Avid?(with the same font&locations)
    John
  • Wed, Jan 20 2010 9:41 PM In reply to
    • Posts 10,214
    • Points 218,175
    Re: Open an STL(EBU) file in avid
    John....
    There are lots and lots of tools to convert files so they are read by SubCap whihc is a feature since MC 3.0.
    Take a look at this http://community.avid.com/blogs/training/archive/2008/08/19/avid-subcap-generator.aspx
    That should answer a lot of your questions.
  • Sat, Jul 23 2011 10:02 AM In reply to
    • cairofilm
    • Joined on Sat, Jul 23 2011
    • Posts 4
    • Points 40
    Hi Marianna - I am trying to use the Subcap generator - but i cannot find a program that would allow me to make a .stl file. I don't know if you have any advice about which common programs to use.
    I tried subtitle workshop, but while this seems to create a .stl file, avid will not recognize it.
    thanks for the advice.
    petr.
  • Tue, May 2 2017 6:37 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 350
    • Points 3,870
    So the STL format doesn't store any formatting information?  (font, colour, drop-shadow, etc)  Is it just the same information as the DS Caption export txt file?   I can read the txt file but the unreadability of the .stl file in a text editor suggested that it was more than just text and timecode in and out?  I thought the advantage of preparing subtitles in Avid with the SubCap effect was that I'd be able to export subtitles the way and OMF or AAF exports audio to a sound editor and allows them to recreate what I did in the Avid with all the formatting.  Is there a subtitle export format that does this?
    Avid Media Composer 2018.11 / Mac OS Sierra / MacPro5,1 / 6-Core Intel Xeon 2.66 GHz x2 / 64 GB 1333 MHz DDR3 ECC [view my complete system specs]
