Latest post Tue, Nov 24 2009 6:24 PM by exmachina. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Nov 19 2009 10:26 PM
    • exmachina
    • Joined on Thu, Mar 8 2007
    • Posts 34
    • Points 530
    entering/exiting effect mode with keyboard in MC 3.5
    I'm running Media Composer v. 3.5.  When I was using Express Pro, I was able to enter AND exit effect mode by pressing ], the default key.  With MC, ] enters effect mode, but will not exit it.  I've had to use [ to enter trim mode, and then press it again to exit trim mode and get back to my normal timelime, or else I have to exit out of the effect window.  This is a very frustrating little niggle, and I wondered if anyone could help.  Assigning effect mode to different buttons doesn't make a difference.
  • Thu, Nov 19 2009 10:55 PM In reply to
    • Justin_Brown
    • Joined on Tue, Sep 22 2009
    • Sunshine Coast, Australia
    • Posts 22
    • Points 310
    Re: entering/exiting effect mode with keyboard in MC 3.5
    I press 'Y' on the keyboard to exit Effects Mode
    Windows 7 Ultimate 64, Intel i7 965, 24gb CorsAir Ram, MSI Eclipse SLI, OCZ Vertex SSD 120gb, 2x300gb WD Raptor Drives, 4x3TB WD HDD, 2x Nvidia 7800GTX... [view my complete system specs]
  • Fri, Nov 20 2009 6:04 PM In reply to
    • exmachina
    • Posts 34
    • Points 530
    On my keyboard, Y and U go to first and last frame of the sequence.  Any other thoughts?
  • Fri, Nov 20 2009 6:17 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Just Map the Effects mode button and the S/R mode button to the keys of your choice.
  • Fri, Nov 20 2009 6:34 PM In reply to
    Y and U on my keyboard are "Go To Previous/Next Locator"
    As BLKDOG says, you can map the keyboard any way you like.
  • Fri, Nov 20 2009 6:36 PM In reply to
    I have the Source/Record Toolset mapped to F11. That always brings me home from wherever I am, Effects Mode, CC Mode, Trim Mode, anything.
  • Fri, Nov 20 2009 7:36 PM In reply to
    Follow Job's example. Use your toolsets to instantly switch from one mode to the other. Customize the size and position of your tools, project window, source and record windows and timeline for any given toolset and then "save current". Further, you can attach a particular customized timeline view to a particular toolset by using the "link to current" dialog.
  • Sat, Nov 21 2009 6:52 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,382
    • Points 96,980
    In C:\Program Files\Avid\Utilities\XpressKeyboardSettings you will find a file called XpressKeyboardSetting.avs.  See if that helps.
  • Tue, Nov 24 2009 6:24 PM In reply to
    • exmachina
    • Posts 34
    • Points 530
    Awesome - that'll work.  I mapped Source/Record to the \ button, so at least they're next door.  Though I wish I could just use the same button like in Xpro.  Oh well.  Thanks for helping me with this tiny, but irritating issue.
