Latest post Mon, Oct 12 2009 8:54 PM by mmullen. 15 replies.
  • Thu, Oct 8 2009 4:55 PM
    • jaysonL
    • Dallas, TX
    • Posts 24
    • Points 345
    Trouble licensing Boris BCC 6.0 for MC 3.5 Nitris
    Just opened a sequence using Boris BCC FX on a new box running MC 3.5.4.  Scene has watermark on it and Effect Palette does not offer a button to enter license as illustrated on Boris website.  Tried reinstall to no avail.  Any suggestions?
    Jayson
    Mac Pro 2.93, 8 GB, MC 3.5.4, Nitris
    MC Meridian MC Adrenaline MC Nitris and Xpress Pro [view my complete system specs]
    Filed under: , , , , ,
  • Thu, Oct 8 2009 5:38 PM In reply to
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Haverhill, MA
    • Posts 568
    • Points 6,500
    Re: Trouble licensing Boris BCC 6.0 for MC 3.5 Nitris
    Jayson,
    There should be a register button in the effect.  It should be located in the topmost controsl set in the effect palette.  If you do not see it, it may be because the effect "group" is not open.  Twirl it open on the left and you should see it.
    -Matt M.
  • Thu, Oct 8 2009 5:48 PM In reply to
    • jaysonL
    • Dallas, TX
    • Posts 24
    • Points 345
    thanks mmullen.
    No, I have all the parameters twirled open.  In fact I have the Bypass and Launch Help File buttons, just no Register button.
  • Thu, Oct 8 2009 6:05 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 568
    • Points 6,500
    Hmm,
    And your getting a water mark?
    Could you post screen shots of the effect pallette and watermark?
    -Matt M.
  • Thu, Oct 8 2009 6:20 PM In reply to
    • jaysonL
    • Dallas, TX
    • Posts 24
    • Points 345
  • Thu, Oct 8 2009 6:23 PM In reply to
    • jaysonL
    • Dallas, TX
    • Posts 24
    • Points 345
    I hope I didn't just upload the pallette shot 4 times...
  • Thu, Oct 8 2009 6:25 PM In reply to
    • jaysonL
    • Dallas, TX
    • Posts 24
    • Points 345
    this is a screen shot from borisfx.com regarding licensing
  • Thu, Oct 8 2009 7:11 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 568
    • Points 6,500
    Jayson,
    Did you install this from a disc or from a download?
    Do you know the exact version of BCC 6 you installed?
    -Matt M.
  • Thu, Oct 8 2009 9:51 PM In reply to
    • jaysonL
    • Dallas, TX
    • Posts 24
    • Points 345
    mmullen:
    Jayson,
    It was originally installed by our reseller and then re-installed this morning from disc.
    Boris Continuum Complete AVX 6.0.4 from disc.
  • Thu, Oct 8 2009 10:23 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 568
    • Points 6,500
    What was the reason for the reinstall today.
    You might want to try installing yet again and see if it removes teh water mark.
    On a side not are these existing effects on a timeline...if you add a new effect does it give you the same water mark?
    -Matt M.
  • Thu, Oct 8 2009 10:46 PM In reply to
    • jaysonL
    • Dallas, TX
    • Posts 24
    • Points 345
    Thanks for helping me all day - its appreciated.
    I reinstalled this morning thinking that may work after the opportunity to enter the code.
    I just tried the reinstall again to no avail.  Same result - watermark and no option to register in the effecte pallette.
    I get the same result in a fresh sequence with a fresh BCC effect.
    Jayson
  • Fri, Oct 9 2009 3:18 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 568
    • Points 6,500
    Jayson,
    I'm going to PM you.
    -Matt M.
  • Fri, Oct 9 2009 5:11 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 568
    • Points 6,500
    For anyone following this.  Looks like Jayson was given a "bad" install code.  He is all set with a new code now.
    -Matt M.
  • Fri, Oct 9 2009 5:30 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,333
    • Points 60,235
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Thanks for following up. Big Smile
    Mac Pro. QHD Ultra wide, thunderbolt LG monitor, MC Ultimate 2018.10.0. Pro Tools 11 HD (Mbox 3 Pro), iPad Pro 12.9". 17" Macbook Pro i7. Dell... [view my complete system specs]
  • Fri, Oct 9 2009 5:43 PM In reply to
    • Posts 10,156
    • Points 217,345
    mmullen:
    Thanks Matt....  great support for Boris.
