Latest post Sat, Apr 11 2009 1:15 AM by AndrewAction. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Apr 9 2009 10:53 PM
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Avid Documentation on folder permission issues.
    There used to be some Avid Knowledge Base documentation about folder permission issues with Avid.  I just ran into one of these issues on a new system, so I tried to find these documents.  I found the forum posts that referenced the documents, but the links led to KB pages that said "no longer available."
    I went to the KB and did some searching, but I can't find the documents that I saw before -- the ones that had the information I was looking for.
    Just in case it matters, the issue I ran into was that I was unable to backup some of my Avid Projects to a drive on a different system -- access was denied.  I first tried checking the box to apply the permission from the "Avid Projects" folder to all the child folders, but this resulted in NO permission settings on all the child folders, which locked me out on even the main system.  I then went into the Advanced security settings for the "Avid Projects" folder and changed the permission setting from "this folder only" (the default) to "all folders, sub-folders, and files."  The "Avid Projects" folder now gives "full" permission to "Everyone," as do all the sub-folders.  This appears to have fixed my access issues, but I'm not clear if this was the right way to solve this issue, so I'd still like to find any further information I can on this.
    Thanks for any help or info on this,
    Larry
  • Thu, Apr 9 2009 11:04 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,146
    • Points 49,975
    Re: Avid Documentation on folder permission issues.
    Try this:
    http://tiny.cc/CbLv2
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2023.3.1 iMac w Big Sur and 2018.12.7 on Windows 10 Boot Camp [view my complete system specs]
    Jef Huey
  • Fri, Apr 10 2009 4:44 AM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Thanks -- that looks more along the lines of what I remember.  It looks like the end result is generally the same as what I ended up with ("full" control for "Everyone"), but it was helpful to confirm this with the info you linked to.
    Thanks again,
    Larry
  • Fri, Apr 10 2009 3:07 PM In reply to
    • jef
    • Maryland
    • Posts 4,146
    • Points 49,975
    Hi Larry,
    I keep that book marked becuase I seem to have lots of issues when I move projects from machine to machine with permissions.  It would be nice if Avid could somehow make permissions control more user friendly.
    Cheers,
    Jef
    Jef Huey
  • Fri, Apr 10 2009 10:56 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,456
    • Points 98,515
    The problem with managing permissions isn't Avid's, it's Microsoft's.
  • Fri, Apr 10 2009 11:04 PM In reply to
    If you're on Vista 64, you can add this functionality to the Right-Click Contextual menu ...
    http://www.vistax64.com/tutorials/112795-context-menu-take-ownership.html
    (wwld)
  • Fri, Apr 10 2009 11:09 PM In reply to
    jwrl:
    True but the problems only began with a bad (IMO) decision by Avid to started using Microsoft user permissions for security and moving most of the Project management into the Microsoft Documents and setting environment.
  • Fri, Apr 10 2009 11:51 PM In reply to
    • jef
    • Maryland
    • Posts 4,146
    • Points 49,975
    I think I agree with Andrew here.  My question is what did we gain by the change that was made?  I can not recall a problem before.  I do not know, I am just asking.  I do know that this has bitten me more than once.
    Jef
    Jef Huey
  • Fri, Apr 10 2009 11:57 PM In reply to
    The projects were already in a "shared" location.  Previously, however, the User Profiles were under the current Windows login account name, under Avid.  If you logged in as another Windows user, the User Profiles seemed to be missing.  Moving the User Profiles to a shared location resolved this.
    (wwld)
  • Sat, Apr 11 2009 1:15 AM In reply to
    Randall L Rike:
    Yes ..... however it came at a cost.  For me the most recent being 40 minutes on a long distance call sorting it for a friend I had persuaded to drop Premiere and buy Avid.
