Latest post Fri, Apr 20 2012 6:33 PM by ode2fame. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Feb 21 2009 2:57 AM
    • J. Difool
    • Joined on Thu, Nov 2 2006
    • Posts 17
    • Points 235
    C for copy (withouth command/ctrl key)
    Hello,
    is there a way to perform copy simply by pressing C (without command key)?
    I tryed mapping the command key over the C but it still doesn't work...
    For me, it would be great to be able to copy and load the cliipboard on the source monitior with a single stroke.
    I thought it should function by simply applying the modifiers Alt and Command to C on the keybord layout but it doesn't.
    Any ideas?
    JDf
    P.S.: I'm working on MC 3.0.5, MacOS 10.5.5
    Filed under: , , ,
  • Sat, Feb 21 2009 9:17 AM In reply to
    Re: C for copy (withouth command/ctrl key)
    Why not map "Copy-to-Clipboard" to the C-button then?
  • Sun, Feb 22 2009 4:20 PM In reply to
    • J. Difool
    • Posts 17
    • Points 235
    Sorry, my post was not so clear...
    I do have "Copy-to-Clipboard" mapped to the "C" key. However, MC only performs "Copy-to-Clipboard" when I press Command-C, when I press C I only hear "clonk" and nothing hapens.
    Is this a problem with a system setting or an Avid setting?
    Are you able to copy to clipboard without pressing the auxiliary key (Command on Mac, Ctrl on PC)?
    JDf
  • Sun, Feb 22 2009 4:30 PM In reply to
    I always use ALT-CMD-C, since I have remapped almost my entire KB, and C is something else on mine.
  • Sun, Feb 22 2009 5:22 PM In reply to
    ALT+C is all that's needed to copy the Marked section into the Source monitor.  CMD is not needed.
    Also, ALT+X will Extract the section from the Timeline and place it in the Source monitor and ALT+Z will Lift the section from the Timeline and place it in the Source monitor.
  • Sun, Feb 22 2009 6:02 PM In reply to
    Kenton.VanNatten:
    Again: not if you have something different mapped to the C-key, as I do. ALT-C works with a default KB. ALT-CMD-C (ALT-CLTR-C) works on all KB settings.
  • Sun, Feb 22 2009 6:05 PM In reply to
    Job ter Burg:
    oh?  I wasn't aware of that.
  • Fri, Apr 20 2012 6:29 PM In reply to
    • ode2fame
    • Joined on Mon, Apr 9 2012
    • Posts 6
    • Points 60
    I'm editing on Avid Media Composer 6 on a MAC.  When i do alt+c it only copies the audio to the clipboard...do you know what i'm doing wrong??
  • Fri, Apr 20 2012 6:33 PM In reply to
    • ode2fame
    • Posts 6
    • Points 60
    Actually, what's weird is that when i switch from source/record and look it seems the video and audio did copy to clip board but you can hear the audio while video is frozen...being funky...
    but when you copy to the clipboard black is in the source window and audio plays...
