Latest post Tue, Feb 10 2009 1:58 AM by davidguaita. 2 replies.
  • Mon, Feb 9 2009 1:53 AM
    • davidguaita
    • Joined on Sat, Feb 7 2009
    • Tokyo
    • Posts 2
    • Points 20
    Anyone having slow responding keyboard?
    Hi all.
    I have a slow response from the keyboard while editing. If I hit the spacebar when playing a clip (even a single clip) it takes some time until it stops playing (like 7 frames). It´s very annoying.
    I'm not using Mojo or Firewire to output any signal, I'm only working with the Pc and the software.
    There´s anyone having the same problem? Any possible solution?
    I don't understand what can be the reason for such delay when you ask the avid to stop : (
    Thankyou
    Avid Media Composer 3.1.2 PC version , Windows Xp Professional, Service Pack 3, Intel Core 2 QUAD CPU 6600, 4 GB RAM, 250 Gb System disk, RAID 0 2x225... [view my complete system specs]
  • Tue, Feb 10 2009 1:43 AM In reply to
    • wmcole
    • Posts 578
    • Points 7,680
    Re: Anyone having slow responding keyboard?
    With 3.1.2 I've had the wierd problem that sometimes space-bar does not stop a timeline that is playing back at all until it gets to the end of the timeline.  Esc, the K key, trying to click the transport control button to stop playback - all are locked out until it finishes playing back the timeline.
    This seems to happen at random, and unless I terminate and re-start MC, it will continue to happen any time I start playback with the space-bar.
    HP z840 dual 8-core; PCI slot 3, Creative SB X-Fi audio card; 32 GB Ram; 4 x 1 TB RAID 5 internal SATA Western Digital Caviar Green Media drives (appears... [view my complete system specs]
    wmc
  • Tue, Feb 10 2009 1:58 AM In reply to
    • davidguaita
    • Tokyo
    • Posts 2
    • Points 20
    Wmcole, Do you have a wacom tablet connected to your PC?
    I had the same problem until I read in a forum that Wacom Intuos 3 can cause that problem. I have disconnected the wacom and the problem is solved. You have to use a mouse then, but it´s ok.
    But, I still have a slow response when hitting the space bar. It´s curious, because I was using Avid Xpress Pro,and I didn´t had that problem, it started when I made the upgrade to Media Composer.
    Maybe is related to the number of files in your Omfi and Mxf directories, it´s possible that if they are too crowded the behaviour becomes sluggish.
