Latest post Tue, Nov 11 2008 2:49 AM by BobRusso. 4 replies.
  • Mon, Nov 10 2008 10:26 PM
    • dogish86
    • Joined on Mon, Nov 10 2008
    • Posts 2
    • Points 40
    True HD through Avid
    Hello everyone!
    Thanks for taking the time to help me out!
    I am trying to find an efficient way to view true HD (1080p/23.976) on Avid using a 56-inch HD monitor. My problem is that I know that in Avid, when I edit my piece(s) using a firewire drive, that effectively disables true HD viewing. So is there an solid method to viewing true HD while I'm editing (after I render, of course)? What sort of equipment/hub is necessary for the implementation of this process?
    Again, thanks for your time! Any posts will be greatly appreciated!
    Filed under: , , , ,
  • Mon, Nov 10 2008 10:40 PM In reply to
    • cable
    • Joined on Sun, May 27 2007
    • Pacific NW
    • Posts 381
    • Points 4,910
    Re: True HD through Avid
    What is True HD vs. HD?  But to answer your question, just plug a cable into the HD-SDI output of your Avid and plug the other end into the monitor and that's it.  This presumes you are using a Nitris DX with fast enough drives to support 1080p not firewire drives.  If not this configuration, then what system are you using?
    20 x Media Composer 8.6.5 Mac Pros 32MB RAM OSX 10.11.6 AJA and Nitris DX hardware Avid Nexis Enterprise [view my complete system specs]
  • Mon, Nov 10 2008 11:53 PM In reply to
    • dogish86
    • Posts 2
    • Points 40
    Slipped when I said "true". I merely meant viewing the edits as 1080p/23.976.
    We are currently using Media Composer Soft. As opposed to purchasing any high end Avid equipment, are there any affordable/inexpensive methods/solutions to our issue?
  • Tue, Nov 11 2008 1:55 AM In reply to
    • Solopost
    • California
    • Posts 1,566
    • Points 18,050
    No.
    SYS# 1- MC6.5 Mac Pro 2xQuad-Core Intel 3.2Ghz 18Gb Ram OS 10.7.5 2Tb storage (mixed SATA/1394/1394b) SYS# 2- MC6.5 Macbook Pro 2.8Ghz (mid-2009) 4Gb... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Tue, Nov 11 2008 2:49 AM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Without hardware the only option is Full Screen Playback. If you need HD-SDI or Component HD a Matrox MXO could be used, but neither is a replacement for Avid hardware.
    I would consider this low cost monitoring. This is not broadcast finishing quality.
