Latest post Wed, Jun 18 2008 7:59 PM by Larry Rubin. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Jun 18 2008 5:35 PM
    Project Restoration
    Hey everyone.  I feel I may have done something really stupid.  I had a single avid project saved outside of the regular AVID PROJECTS FOLDER (but on the same drive).  I decided to organize things better and move that individual project into the AVID PROJECTS FOLDER with everything else.  The moment I did so, my project became inaccessible and Avid doesn't read it anymore.  I was wondering if anyone can tell what I did and is there any way to restore the project?  Thank you all so much.
  • Wed, Jun 18 2008 5:39 PM In reply to
    Re: Project Restoration
     Check you path as defined in the main select project window. If necessary, click on the browser icon and re-define the path to the projects folder.
  • Wed, Jun 18 2008 5:54 PM In reply to
    I tried that with no luck.  Avid doesn't recognize any of the files for that specific project.  Everything else I'm working on comes up.  It's as if when I moved that project into the big PROJECTS FOLDER all of the contents just vanished and the folder became corrupted.
    Even when I check the properties the folder it says there are no contents and I cannot access it.
  • Wed, Jun 18 2008 7:20 PM In reply to
     Then it's time to find that project in the attic files and copy it's bins to your desktop, change the bin extensions to .avb, create a new project and use the open bins command to open the attic bins on your desktop inside the project and see if you can recover from that point.
  • Wed, Jun 18 2008 7:49 PM In reply to
     You, sir, have saved my life!  I cannot thank you enough!
  • Wed, Jun 18 2008 7:59 PM In reply to
     You're quite welcome. I'm glad that solved the problem for you. The attic is quite often a real lifesaver. Been there...done that!
