I have an error message : "Lost connection to server" in the client Adrenaline. The workspace unmount and mount 15second after... It's a big problem when the project is on the workspace..... The installation is : 15 clients Adrenaline 2.7.7 Macpro os 10.4.10 1 client Protools 7.3 mac G5 2 clients Nitris Symphony 1.7.7 and Server Unity Medianetwork 5.0.1 - 40To - fibre Excuse me for the mistake, i'm french..... :-)))
Ted Simbajonhttp://www.tedsimbajon.comHead Janitor
AvidForum.com
You are aware that ProTools are not supported with MadiaNet 5, aren't you?
See if it gets better when ProTools are off.
bengo82:... i had a "lost connection" message to a client when an other client shutdown....
What you should do is check the Unity event logs every time you lose connection, especially when a client powers up or shots down.
This all looks OK.
It is possible, that you have a faulty component somewhere in the Fibre network, which propagates the fault somewhere else. That's the problem with Fibre Channel - a bad drive or even an SFP may cause a failure some place you'd never think is of.
I think you are in for a challenge. Try to look for a pattern of some sort. Make sure the disconnects are not timed to booting or restarting computers. Keep a close look at the File Manager's event list and drive errors in the Unity Monitor. With so many clients it may take a while to find the colprit.
