Hi
I would just like to confirm the above is true. The auto logon feature should also be introduced, default it should be off with the option to enable it. Like Nexis client. Avid link could also do with user access rights, an administrator which can view the whole account and single user which can only activate-deactivate a specific machine.
Adobe has the teams feature which sort of does this, but I'm no Adobe licensing expert and have only looked at it and set it up once.
Jeroen van Eekeres
www.mediaoffline.com
Have you turned OFF Admin functions in Avid Link?
Admin Functions: Administrators can use this option to limit the features of Avid Link, such assoftware installations and Activations. You must be logged into a local administrator account inorder to set/change admin functions in Avid Link.
Additionally, according to the Avid Link guide (not tested myself), Any users added to a local or network user group called "Avid Link Restricted Users" will not have the ability to download or installsoftware and will not be able to modify Activations in any way. When a user added to that group opens Avid Link they should see the text [restricted] in the Avid Link title bar.
I have not yet tested the group Restriction but am eager to give it a go.
Charles
Subsequently, I did confirm that clicking Go To MyAvid in Avid Link bypasses the website sign in page. Avid - big no no.
I am trying to evaluate Avid for our company, using Avid First. But we're stuck. Avid Link won't connect, omegle and eventually crashes. Can anyone help?
Well, Avid logged it as a feature request; it's been almost a year and a half and no change. It's an easy one to implement, but evidently it was assigned a "sometime/ever" priority.
Remove passing sign-in tokens between Link and the web browser in Link's "Go to MyAvid" command.
