Using relational CC in Symph is fast but sometimes a clip from the same tape or master clip with change halfway through a scene - for example a scene starts off indoors, then during the course of the scene moves outdoors or to a location that is lit differently. The clip still belongs to the same master clip but now it needs a new set of uniform corrections for the rest of the scene.
Currently what I seem to have to do is correct the majority of the clips using the Master Clip relationship and then go back and Src Segment the clips that need a differemt correction.
I'd like to be able to tell Symph; After this timecode, treat clips from this source as a new, but still related, series of clips. Or perhaps between a marked region so I could select the portion of the timeline I want the changes to occur in.
Bit picky I know, but would be a timesaver.
Andi
