Hello
I am trying to export from MC020 on Catalina, working in Apple ProRes, the project was begun on a pre-Catalina version the started on MC 2020 by mistake. I am trying to export a sequence as a MOV. I have exported two small subclips of the final timeline (about a minute) as a test, they worked fine. When I came to export the final programme (70min) all I got was black and no audio, but it did export. Before trying to export the sequence again I tried a test; I made subclips of the sequence and got this error message "Could Not open file because "Invalid File Name". I made a new small sequence, same error, I tried with the subclip that had successful exported but the error occured, I tried exporting as aff, I swapped user settings, ( on starting MC2020 I had created my own new settings) But still the same error. Does anyone have any idea:
A) What the problems is
B) How I epxort to mov ?
The export setting I used were: export as .mov, raster same as project, codec H264, compression H264 Audio Linear PCM. Basically all the setting I have been using for years.
Thank you
Was there any file in the sequence that had a filename that had any odd characters, especially slashes, backslashes, bars, etc.?
Keep in mind – that includes not only the file itself, but also any folder above that file. So if a filename was /Volumes/Macintosh HD/Documents/Media/Avid|Files/Project1/File1.mov, that Avid|Files is probably going to cause a problem.
Just to be sure, you're using the new H.264 export option, right? The way you describe it, it sounds that way. Just want to make sure. If it's a process you've been using for years, the "correct" way might be a little different now. But based on your description, it sounds like you're in the right place.
Hi
Thank you for your response.
I will check this, I am working remotely on my director's equipment so this is happening over the phone.
As a far as I remember we have not changed any file names since the successful exports. I am not sure what the new H.264 settings are, I am just selecting that as an option in the export window along with .mov. Is there another place this is hiding ?
Also are you sure you are exporting to a location path that has no invalid characters as well as your export file name.
To be sure try exporting using a simple file name like test.mov into a simple folder off the root level of a drive.
Just to be sure thats not the cause.
