Latest post Wed, Apr 17 2019 11:16 AM by Pixel Monkey. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Apr 17 2019 8:25 AM
    • pjanna
    • Joined on Wed, Mar 27 2019
    • Posts 12
    • Points 150
    batch re-import and relink
    Hi!
    I was wondering that what is the difference between batch re-import and relink?
    Thank you for help!
  • Wed, Apr 17 2019 11:16 AM In reply to
    • Pixel Monkey
    • Posts 1,240
    • Points 15,655
    Re: batch re-import and relink
    Very different. The difference has to do with the method they were originally imported.
    Batch re-import is for things that were brought in via File->Input->Import Media. It was renamed somewhat recently. It used to be called simply "Batch Import".
    Relink is to tell clips or a sequence that contain offline media to re-link to that media. It is also used for the "offline/online" workflow, to unlink to existing low-res media and link to high-res media or even the original AMA-Linked camera cards.
    Google "Avid Relink", "Avid AMA Workflow" to discover the relink process.
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
    WWLD (What Would Larry Do?)
    WWND (What Would Norman Do?)
