Latest post Mon, Apr 22 2019 3:33 PM by Marianna. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Apr 11 2019 11:52 AM
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 472
    • Points 6,420
    Audio clip FX error - anyone else had this?
    I've been getting an error when I try to render Audio Clip FX. but not every time.
    I was using the RX6 voice de-noiser (which is fantastic) however on some clips on the same timeline I am getting this error. Some clips are fine and others not. It seems the clip which create the error consistently do so. And it is not just the RX6 plugin it seems; I have tried a few of the other clip effects including those included with MC and all give the error.
    If I close the error window by clicking 'continue' I can then delete the effect and carry on editing. If I dont dlelte the effect the error warning re-occurs when I try to play the timeline.
    I don't appear to be able to upload the screen grab!  The error message reads:-
    An error has occurred:
    Audio consumer duration differs from video edit duration by -6.000000 samples.
    File: s:\coresw\ame\src\player\match.c, Line:6152
    the options are:- 'Create report', 'Exit Application', 'Continue' and 'Debugger'
    I'm on MC 2018.12
    Any ideas?
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 32GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 411.95) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Mon, Apr 22 2019 3:33 PM In reply to
    • Posts 10,214
    • Points 218,175
    Re: Audio clip FX error - anyone else had this?
    MattB
    Apologies or the delay .... caught up from 8 days at NAB finally.    I know Zach had this one time before and the issue was with  the audio.
    That is what was exhibiting the problem..... temp ADR that was brought in long ago, probably in a 23.976p project.
    Worked fine in 2018.5.0, but exhibits errors when rendering audiosuite effects applied to those same clips in 2018.12..x
    A good bet is that the audio was imported at 23.98 and when placed in the timeline as a clip with certain durations the sample calculations are not working out (not sure how to end up under by 18 samples, but that's what the error message points to).
    Give that a go.
    marianna
