Latest post Thu, Apr 11 2019 11:24 PM by Telegram!. 4 replies.
  • Thu, Apr 11 2019 12:07 AM
    • cable
    • Joined on Sun, May 27 2007
    • Pacific NW
    • Posts 386
    • Points 4,965
    maximum still image dimension size
    I am trying to find the limit for importing a still image into MC 8.6.x or MC 2018.x.  I've been given an image that I'm sure is too large but I thought I'd try finding out what the actual number is. I've tried the manual and an online search without luck. The image I'm working with is 40k x 34k. The error is 'image size too large'.
    Anyone know the actual number?
    Thanks.
    20 x Media Composer 8.6.5 Mac Pros 32MB RAM OSX 10.11.6 AJA and Nitris DX hardware Avid Nexis Enterprise [view my complete system specs]
  • Thu, Apr 11 2019 2:07 PM In reply to
    Re: maximum still image dimension size
    cable:
    Thanks.
    I know I’ve hit the limit, but don’t recall. Did you try Pan & Zoom? Or Import? Or Link?
  • Thu, Apr 11 2019 5:15 PM In reply to
    • cable
    • Pacific NW
    • Posts 386
    • Points 4,965
    OK. So 16k x 16k 72dpi works, 17k x 17k dpi does not. So it's probably a 16-bit limitation.
  • Thu, Apr 11 2019 8:52 PM In reply to
    • cable
    • Pacific NW
    • Posts 386
    • Points 4,965
    I should point out that I'm talking about importing an image (not linking and not using pan and scan). I did tests though and found that on MC 8.6.5 and on my macbook pro laptop (2018) I can link files up to 11k x 11k 72 dpi and I can use files up 24k x 24k 72 dpi using pan and scan's import.
  • Thu, Apr 11 2019 11:24 PM In reply to
    I thought Pan & Zoom might offer a large file. It might be total file size that’s the limiting factor, I don’t know. Good luck.
