Latest post Thu, Apr 4 2019 6:38 PM by Martin in Chicago. 13 replies.
Page 1 of 1 (14 items)
  • Thu, Mar 28 2019 3:26 PM
    How do I turn off Audio Scrub?
    I've been away from Media Composer for a while and now that I'm back and updated, I've either forgotten a few things or they've changed.
    1. How do I turn off Audio Scrub? It used to be that I had to either hold down the shift key or put on the caps lock key to get audio scrub. Now those choices apply if I am using the one frame forward or backward keys, but if I drag through the timeline, the audio plays even when shift or caps lock aren't engaged. I'd like to have control over that.
      1. Am I remembering incorrectly
      2. Is there a new setting somewhere I can't find?
      3. Is this a change in approach?
      4. Is this a bug?
      5. Is this an issue of my using a no longer qualified computer?
      6. Am just I hearing things?
    Martin
    MC 2018.11.0, OS 10.13.6, Early 2009 Nehalem MacPro4,1, 2 X 2.6 GHz Quad-Core updated with Samsung 850 EVO 1 TB system drive, 32 GB RAM and ATI Radeon... [view my complete system specs]
  • Thu, Mar 28 2019 6:49 PM In reply to
    Re: How do I turn off Audio Scrub?
    That IS weird... most definitely if caps-lock is not one you should not be getting audio scrub.
    Did you try creating new user preferences?
    J
    Hackintosh OC'd 4.9 GHz i7-7700k, AMD Radeon Vega 64, 64 GB RAM, SSD, 8x Fibre to Terrablock, BM SDI 4k, currently running Mac OS 10.14.3. Symphony... [view my complete system specs]
  • Thu, Mar 28 2019 7:13 PM In reply to
    Jason,
    I hate it when new settings is the correct answer. Huh?
    But wait! Turns out that creating new settings then returning to the old settings got rid of the problem.
    Curiouser and curiouser. Killer App for a limited market: an Avid Users Settings updater that removes confilcts and lists the things you have to redo yourself.
    Martin
  • Thu, Mar 28 2019 7:16 PM In reply to
    Martin in Chicago:
    I'm with you! Who knows if that EVER has really done ANYTHING but I still religously create new ones whenever a big update happens just in case... 5 minutes of time for nebulous security I guess...
    J
  • Thu, Mar 28 2019 7:27 PM In reply to
    Jason Sedmak:
    …I still religously create new ones whenever a big update happens just in case...
    Sure, a great idea and I do try, but five minutes my behind! My settings are twenty years worth of meddling. It takes me forever to rebuild them.
    Martin
  • Mon, Apr 1 2019 4:31 PM In reply to
    • Editmvp
    • Joined on Wed, Sep 3 2008
    • Billings, Montana
    • Posts 144
    • Points 1,725
    I have screen shots of all my settings that I use for reference when rebuilding User settings.  Just open up the Keyboard settings and make a screen grabs, including with Shift (or other modifiers pressed).  Really speeds up the process.
    Primary System: Media Composer 2018.12.3 w/Symphony Option | Phrase Find | Avid Artist DNxIO | Mac Pro Mid 2012 12-Core 3.46 | OS10.13.6/64GB/1TB-SSD/Quadro... [view my complete system specs]
  • Mon, Apr 1 2019 4:35 PM In reply to
    Editmvp:
    Great tip and I do have those and it does save time. Still takes a while though. I tend to not think to do it till I'm ready to start a new project and realize I haven't done it.
    Martin
  • Mon, Apr 1 2019 7:02 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,427
    • Points 41,320
    I agree with all said here, BUT ....
    I have found that the forced act of opening all these settings has lead me to discovering software changes / updates that were not clear to me from the doc or had changed in a version I had skipped.  So, useful in the long run.
    Jef
    Jef Huey
  • Mon, Apr 1 2019 7:10 PM In reply to
    Absolutely—and, hey, how are you Jef?—but, still, it can be challenging to fine the time and it is an editor's perogative to complain from time to time.
    Martin
  • Mon, Apr 1 2019 7:17 PM In reply to
    • jef
    • Maryland
    • Posts 3,427
    • Points 41,320
    I am great - you?
    But you know me - I would NEVER complain (cough - sputter - cough)!
    Jef Huey
  • Mon, Apr 1 2019 8:38 PM In reply to
    jef:
    I am great - you?
    Over ambitious, under employed, and ready for the Chicago cold to be gone. Bet it's lovely by now in DC.
    Martin
  • Mon, Apr 1 2019 8:48 PM In reply to
    Martin in Chicago:
    Jason,
    Martin
    There is an update settings option that sometimes helps and if you know how you can copy specific settings from one set of settings to another.
  • Mon, Apr 1 2019 9:26 PM In reply to
    Pat Horridge:
    Wow, I wonder how many years that's been around without my notiicng it. I just tried it and am eager to see how it performs. Thanks for the tip Pat.
    Martin
  • Thu, Apr 4 2019 6:38 PM In reply to
    OK, I broke down and started rebuilding my settings. Here's where it's currently got me.
    MartinConfused
