Latest post Mon, Mar 18 2019 2:20 PM by Marianna. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Mar 18 2019 12:07 PM
    • JD_F
    • Joined on Wed, Jun 5 2013
    • Posts 10
    • Points 140
    Where do I find "All Settings" ?
    Hi there,
    I'm trying to access "All Settings" in the Settings tab in the Project window. I want to adjust audio settings so that pitch corrects during jog and shuttle. However, the menu button that normally appears in the setting tab isn't there. How do I switch to "All settings"?
    6.5.2 MC - software only PC, WIN 7 64 bit, i5-2400 CPU @ 3.10, 3.30, 8 GB RAM, NVIDIA GeForce 9600 GT [view my complete system specs]
  • Mon, Mar 18 2019 12:25 PM In reply to
    • Posts 10,214
    • Points 218,175
    Re: Where do I find "All Settings" ?
    Dpends on the version of MC...
    From the Settings list in the Project window, you can view, select, open, and alter various User, Project, and Site settings. Within your Avid editing application is the Settings tab. The Settings tab is located within the Project window.
  • Mon, Mar 18 2019 12:36 PM In reply to
    • JD_F
    • Posts 10
    • Points 140
    Marianna:
    Well yes, obviously.
    I need to access "All settings" in the settings tab. Normally that would be done by selecting the menu button and changing from "Active settings" to "All settings", but I can't find the Menu button on MC | First.
    See in this screen capture. The menu button is normaly where the red arrow is, but on First it's not located there. Where do I find the "All settings" option?
  • Mon, Mar 18 2019 12:49 PM In reply to
    • Posts 10,214
    • Points 218,175
    JD
    First is different..... what version are you on exactly?
  • Mon, Mar 18 2019 12:53 PM In reply to
    • JD_F
    • Posts 10
    • Points 140
    2018.12.1 - should be the latest.
    I normaly work on MC but currently have to deal with a workstation that runs a freshly installed First version.
  • Mon, Mar 18 2019 1:09 PM In reply to
    • Posts 10,214
    • Points 218,175
    First has the settings as follows
    The Project window has tabs that allow you to choose
    • Settings - lets you view and modify settings.
    Publishing is different........  you can save the settings in the Publish dialog box as a profile so you can recall those settings when publishing a movie where you want to apply the same settings.
    M
  • Mon, Mar 18 2019 1:17 PM In reply to
    • JD_F
    • Posts 10
    • Points 140
    I'm sorry but that doesn't answer the question. I know that the project window is supposed to have tabs, but as you can see on this screen shot, it doesn't. All I can see are the basic settings you see in the pic. I need to get to All Settings, to adjust Audio Settings.
    As you can clearly see on the screen shot, there are no Audio Settings. Normally, I would have to select "All settings" to make them visible. How do I do this on this version?
  • Mon, Mar 18 2019 1:32 PM In reply to
    • Posts 10,214
    • Points 218,175
    http://resources.avid.com/SupportFiles/attach/MC_FirstUserGuide.pdf
    start at page 390.....
  • Mon, Mar 18 2019 1:36 PM In reply to
    • JD_F
    • Posts 10
    • Points 140
    Thanks, but I've already viewed this. No new info there.
    Is there no "All Settings" option on First? and if not, how does one alter Audio settings on First? The document doesnt provide answeres.
  • Mon, Mar 18 2019 2:20 PM In reply to
    • Posts 10,214
    • Points 218,175
    The software doesnt have All like MC... you can use the audio mixer tool to modify the audio in the timeline.
