Latest post Sat, Jan 26 2019 4:07 PM by Adrian Redmond. 2 replies.
  • Sat, Jan 26 2019 3:27 PM
    • Adrian Redmond
    • Joined on Wed, May 28 2014
    • Posts 162
    • Points 2,250
    Disable automatic trim mode?
    The trim editor is nice, but it is often not necessary for many cuts, in which case it is tiring to have Avid go into trim mode automatically every time I click on a edit point, use the "go to next cut" shortcut key etc.
    Is is possible - or could it be possible - to prevent MC automatically invoking trim mode, unless I expressly ask it to?
    Avid Media Composer v. 8.5.3. with Symphony Option on HP Z820 Dual Intel E5-2640 6-core HT 2.5GHz CPU 32GB RAM NVidia Quadro K4000 Graphics on Win7x64... [view my complete system specs]
    Adrian Redmond
    Owner / Producer / Editor
  • Sat, Jan 26 2019 3:40 PM In reply to
    • TrevorA
    • Posts 1,095
    • Points 12,520
    Re: Disable automatic trim mode?
    You need to assign & use FFW/REW buttons not 'jump to next/previous cut' (which are A/S by default)
    https://community.avid.com/forums/t/77876.aspx
  • Sat, Jan 26 2019 4:07 PM In reply to
    • Adrian Redmond
    • Posts 162
    • Points 2,250
    This must be the most useful and rewarding tip I've received from the forum today - especially with the attached link that also advised to set the composer settings FF/RW option to "ignore selected tracks" Now I'm cooking on gas....
    Big thanks to TrevorA :)
    Adrian Redmond
