Latest post Wed, Jan 16 2019 11:40 PM by NYnutz. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Jan 14 2019 11:42 PM
    • dklein
    • Joined on Thu, Mar 15 2012
    • Posts 56
    • Points 815
    DeviceDisappeared event detected on md device /dev/md14
    Hi all,
    This our editors started complaining of speed issues and MC 2018.5 started reporting some Exceptions. As this was happening across projects and workspaces, we went to check out our NEXIS log and noticed that around the time editors are gertting errors we're seeing the following error:
    It's also followed by a detected capactiy changer info line: md14: detected capacity change from 26197557248 to 0
    Some time later there will be a warning that a NewArray event is detected for md14:
      mdadm TGroupSDA-top NewArray event detected on md device /dev/md14
    The NEXIS and all clients are 18.9.1.16. Any help woul dbe appreciated.
  • Wed, Jan 16 2019 11:40 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 336
    • Points 3,910
    Re: DeviceDisappeared event detected on md device /dev/md14
    if this was a single SDA SSD, i would expect to see the device listed as /dev/sdX/serialnumber, however, /md is multiple device, as in a raid group. I wonder if both of the SDA metadata SSDs are going offline simultaneously - controller or chassis failure. You should get in contact with avid support URGENTLY.
    Dave
    "A very big network"
