Latest post Fri, Feb 4 2022 3:50 AM by Dave Avid PM. 187 replies.
Page 2 of 13 (188 items) < Previous 1 2 3 4 5 Next > ... Last »
  • Sun, Jan 20 2019 9:55 AM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 284
    • Points 3,410
    Re: Avid Titler+ - The good, the not-so-good and the ugly...
    bonang:
    Fazz Powell:
    one word: INSCRIBER. Buy it, port it to AVX2. :)
    INSCRIBER! I had Inscriber in my online all-component suite 25 years ago - it was fantastic (on a Targa card, GPI triggers, etc.). Also had our 1st Avid then too - strictly editorial and remained that way until AVR 77, when it started to receive very limited finishing use. Throughout there was the Title Tool, whose biggest upgrade of all time was receiving soft shadows sometime around 2000.
    Sadly, the current Title Tool, with all its faults and limitations, is functionally better than the Titler+ just introduced - an embarassment. I, like, many many others, am sorely disappointed at this 1st release, especially with all the fanfare Avid created prior to release. Or, Avid, perhaps not too late - just buy and port Inscriber for inclusion in MC.
    +1 Yes
    Inscriber is indeed the best title software ever made! I used them on my first NLE's, that were Matrox DigiSuite systems. Never found anything like it again. Inscriber CG was for simple titles, TitleMotion for animated text, and TitleMotion Pro could even animate 3D characters back in the late 90’s early 2000. What a pity that such a wonderful character generator got send to the bone yard.
    Applications that are around today like; NewBlue FX, Avid FX, Boris RED and Title Studio don’t even come close. The only solution out there is After Effects, what is a too big hassle.
    Like others suggested. Buy this old titler from Harris and make it work in Avid. Idea
    [AVID 1] HP Z840 | 2x 18 Core Intel Xeon E5-2699v3 / 2.3GHz 35MB | 128GB PC4-17000P 2133MHz / 8x 16GB DDR4 | NVIDIA Quadro P4000 / 8GB GDDR5 / 4x DP 5K... [view my complete system specs]
  • Wed, Jan 30 2019 2:16 AM In reply to
    • Kate Ketcham
    • Joined on Wed, Dec 3 2008
    • Burlington, MA
    • Posts 17
    • Points 335
    • ! Avid Employee
    Hello everyone -
    As part of Avid’s commitment to not only improving the new Media Composer Titler but also ensuring you’re aware of those improvements, I wanted to make sure you knew of the latest updates and changes in Media Composer 2018.12.1, which was released yesterday.
    This information can be found in the ReadMe with illustrations, as well.
    Selecting Gradients in the Avid Titler Tool
    We’ve adding the ability to assign gradients Titler tool. Gradients can be assigned to the Face, Shadow, Edge, Frame and Background by clicking the button next to the color chip to toggle between solid and gradient colors. One thing to note is that the mini button is used to cycle through the available options; it’s not an enabler/disabler of gradients (vs solid colors).
    Titler and In/Out Points
    The Titler now obeys In/Out points on the Timeline. When you have an In/Out point, you can drag and drop a Titler effect in between the IN/OUT points on an empty region and the effect will respect the IN/OUT points. Clicking on T+ button after having selected an empty region will also respect In/Out points.
    Adding Effects to IN/OUT Points
    This change also allows you to add any effect to a region in the sequence marked by an In/Out point and have the effect apply.
    Titler+ Text Box Changes
    When you open the Titler (T+) you’re presented with a large text box – this is not the safe area as some users had believed. The text box allows you to click anywhere on the screen and start typing.
    In addition, if you click on the T (text) button, a new text box will be created in the center of the screen.
    Finally, text boxes with dashed lines indicate that they are not currently selected; a text box with handles indicates that it’s the selected element.
    Animation Clarification
    Translate, Scale, Rotation, Skew, and Origin parameters in the Effect Editor can be animated for text boxes and shapes. Currently we’re recommending that you have a single text box selected when using animation, otherwise the animation might not behave as expected. We’re working on allowing each object to have its own animation for a future release.
    Rotation Clarification
    Some users were unclear about how the rotation parameter in the Titler Tool worked. This parameter rotates each character on its axis; to rotate the entire text box, use the Z Rotation slider in the Effect Editor.
    We know we have additional improvements to make (improving the selection model, expanding animation support, etc.) which we will release over the next couple of months. While we hope these changes improve your experience with the new Titler Tool, we know there’s more to do to make it truly enjoyable. Please continue to provide detailed feedback that we can use to make the tool better.
    Director of Product Management  Media Composer
    Avid
    65 Network Drive
    Burlington, MA 01803
  • Wed, Jan 30 2019 5:58 AM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 476
    • Points 6,550
    Thanks for the update. I'm waiting to upgrade but does it give you real time coordinates of the position of each line of text? Word wrap with less leading, than a new line, for two+ line bullet points. Like someone said have the ability to control size of that bounding box for the text. Return spawns a new line with a higher leading value to separate from the line above. Vertical placement is important data to have real time. Also can you set multiple V margins, H baselines, position them at will, and assign justification properties to each margin? Can one constrain the text to margins, or un-constrain. CTL+ = Nudge font in word. Does it support 32 bit art/logos and the alpha channel? Texture map image or video to a geometric shapes. Have shapes with bevels, and other properties like inner shadow/drop shadow. Animate crop and text bullet builds etc. (whisper Inscriber.) :) I liked the chicklets for the job on the side too. Very basic demo, this titler came out in 1993 ... https://www.youtube.com/watch?v=EOKJRrgveT8
    MC 2020.06 w/Symphony option. BlackMagic DeckLink 12G, HP Z840 Dual 3.2Ghz/8 Core, 1TB SSD, 1TB Cache drive, 128GB Ram, Nvidia RTX2060 Super, BCC2020,... [view my complete system specs]
  • Wed, Jan 30 2019 11:19 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,996
    • Points 38,075
    • Trusted Users
    This is a huge timesaver. Thanks!
    Kate Ketcham:
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Thu, Jan 31 2019 12:05 AM In reply to
    Justification seems off with Avid Titler+. It basically works for left justification but for center, it scrolls way off the the right.
    Avid Media Composer 2020, OSX 10.15 Mac Pro 2019, 16 core, 48 GB memory. [view my complete system specs]
  • Thu, Jan 31 2019 1:53 AM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 588
    • Points 7,080
    Thanks for the new Titler+, will make a huge difference to our workflow.
    Two things I've come across so far.
    1. Underline doesn't get an edge when you add an edge to text.
    2. Issues going from Mac to PC. I just tried moving a sequence with Titler+ effects from Mac 10.13 suite to Win7 suiet. First time the sequence opened but the titles were all blank. No text or rectangles or anything else visible although the settings in the effects editor seemed to reflect what should have been there. Opened the project again on Mac and titles that I had tried to edit on the PC were still blank. Others were ok. Going back to the PC and Avid crashed every time I tried to open that sequence. Deleted the Titler+ effects on the Mac and can now open the sequence again on the PC. So looks like some incompatibility there? I probably didn't start off well by using a random font on the Mac that wasn't present on the PC...
    cheers
    Campbell
    8.5 on a mongrel PC, Win 7, QT7.5, Nvidia GTX 970, 16Gb RAM, SSD, NAS for raw media and a Macbook Pro [view my complete system specs]
  • Thu, Mar 7 2019 9:01 PM In reply to
    • DaveS
    • San Diego, CA
    • Posts 237
    • Points 2,870
    In the effect editor it would be great if there were controls under the Global section for position, scale, rotation, etc. for the entire effect. The idea being that I could compose the title with various elements in place - even be able to animate them individually. Then I could slide the whole thing on screen at once, for instance.
    If that functionality is there like most other effects, I just don't see it in 2018.12.1 on Windows.
    2021 Apple Silicon M1 MAXBook Pro. 32 GB RAM. Running MC Symphony 22.7.0 OWC Thunderbolt dock, various external drives. Editor for Hire. Spots to... [view my complete system specs]
  • Fri, Apr 5 2019 12:35 AM In reply to
    • Doug Abel
    • Posts 38
    • Points 480
    I'm on2018.12.2 and I'm sort of baffled that this has been botched so badly.
    We need the ability to make quick titles and that's that. Whatever this thing is, it's weird and not intuitive. All sorts of voodoo with sliders resetting themselves after settting them.
    Equally embarassing for going on more than a decade (?) is the pan and zoom plugin. These are two areas where Premeier and FCP got it more or less right on the first try. I bet my productivity on a doc would be 10% improved if Avid could just copy how it works elsewhere rather than try to reinvent the wheel.
  • Tue, Apr 16 2019 5:53 AM In reply to
    I know this isn't even a post ... but knowing what can be done with software these days, and knowing what kind of title software that are out there today, and knowing that this took Avid I dont know how many years to figure out - it's hard to even understand how they're still in business. This Title tool must be somebodys idea of a bad joke.
    Media Composer 2018.12.2 Mac Pro, late 2013, 2.7 GHZ 12 Core Intel Xeon E5 64 GB 1867 Mhz DDR3 memory AMD FirePro D700 6144 MB [view my complete system specs]
  • Tue, Apr 16 2019 6:54 AM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 476
    • Points 6,550
    Don’t get me beating my Inscriber drum again. If nothing else these developers should get a copy and see what a real character generator does. I’m saddened by the inability for avid to ever have a decent titler. AVX2 killed the inscriber avid plug-in which I think GVG or Harris owned at the time but no longer uses it for their now dead nle. The code should be out there and cheap to acquire and improve upon. I’ve been using Boris Red, bought, struggled with NewBlue. Paid $6k on Type Deko which died and $4k for Marquees which I never used due to rendering time. When we switched from discreet edit to avid I offered to fly down an avid engineer and put them up for a few days to demo inscriber. There were no takers.
  • Fri, Apr 19 2019 5:55 AM In reply to
    sure there are many title tools out there. that are simple and work. I'm just flabbergasted as to the buggy unintuitive. Clunky, weird attempt of an integrated title tool. Almost decades on its way...
    I'm done with Avid all together, for an NLE. Ufortunately most post houses use Avid still, so for this movie ive been editing, I've been forced to work in MC, so that my editor and me can easily merge projects.
    Everything takes 4 times longer in Avid. FCPX is super quick. So is Resolve, which is what i'll use. And it's free ....  though I have the paid version. It's a joy ride to work in that. Even in FCPX. Plus general support in Avid is no good. Never had to deal with support for Resolve. I could imagine it sucks too. Apple is the only one that has figured out costumer care. So i could imagine fcpx support is better.
    anyway I apologize for the rant to however from Avid who would read this. I'm just done. Moving on.
  • Fri, Apr 19 2019 3:42 PM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 284
    • Points 3,410
    Ulrich Thomsen:
    Don't let me laugh, and don't get me started on Apple and their lousy customer care! Back in the Final Cut Pro 7 days they even couldn't run their own software on their own certified Mac Pro workstations without any big problems. Customer care my *ss! Zero, nul, nada, njet, nougabollen. Super Angry
    That is why I am happily and completely back on the good old trusted Avid. Yes
  • Thu, May 9 2019 12:19 PM In reply to
    • Ben Hills
    • Joined on Wed, Oct 17 2007
    • London, UK
    • Posts 39
    • Points 535
    Honestly, this feels like the nail in the coffin...
    I use avid every day.. but in 5 years, I can’t actually believe that will still be the case. Did the developers look at any existing solutions by other companies, or did they just say “hey, I’ve heard about this thing, why don’t we have a crack?”
    To not just be a troll, jumping on with the negative feedback, specifically, I’ve just downloaded the latest version of Avid (2018.12.3) and I’ve tried to write one simple line of text using the new Titler+ (which, can you believe it, I was ACTUALLY excited to try out..).
    You tap on the screen and a cursor appears. So far so good. You start typing. OK. You carry on typing and the text vanishes off the side of the screen. Nope. Ok, I can get around this. Naturally, like any other softare, you grab the corner of the bounding box. Rather than resize just the box, it scales down the font, so it’s now smaller. Not good. My cursor icon changes over the font size adjustment box. I click and drag... absolutely nothing.  I carry on typing anyway.. the text goes off the screen again..? Why? Ok, so I use the return key, start a new line. Now the whole text box is moving down the screen, taking the font with it. Just odd. I try and grab the bounding box at the side, rather than the corner. YUK! It’s now squashing my font! Why? Why is this so difficult?
    Now, maybe I’ve not been trained to use Titler+.. but really, look around at other software. You shouldn’t need training to write 2 lines of text. You don’t in Photoshop, Premiere, Final Cut 7, FCPX, Resolve, Edius etc. Please, PLEASE look at the competetition to design these tools and then please get actual editors, even non-editors, kids, to test it. And then refine it and test it again. And then realease it!
    Mac Pro 2019 OSX & Windows 10 [view my complete system specs]
    Filed under: ,
  • Sat, Jun 22 2019 8:22 PM In reply to
    • Bandido
    • Posts 101
    • Points 1,135
    Agree, this is ridiculous. How can they proudly announce a new feature that doesn't even work right?. It's been six months since the release of the Avid Titler+ and I can't find a single video tutorial on how to use it. Wonder if the certified trainers could figure it out.
    Mid-2012 Quad Core 2.6ghz Macbook Pro, 16GB Ram, Mac OS 10.13.6 High Sierra, Media Composer 2018.12 with Symphony option. [view my complete system specs]
  • Fri, Jun 28 2019 1:56 PM In reply to
    Bandido:
    Yes, please release a tutorial.   I've been searching for at least some minimal documention and haven't come up with much.   I'm still sticking with the old reliable Title Tool for HD projects and creating lower 3rds and graphics in Photoshop for UHD projects.
    MC 2018.12.3 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system... [view my complete system specs]
