Latest post Mon, Oct 10 2016 5:07 AM by cozzie. 4 replies.
  • Sun, Jun 18 2006 8:00 PM
    • stickboy
    • Posts 5
    • Points 45
    track-1 not found
    so i have done the search on this, and have not found a solution to this problem...i have a sequence that gives me this error message, and tech support claims that it is corrupt media.  so i have tracked the issue to audio, and here is where things get strange, the corruption is only on even audio channels.  i found a corrupt piece of audio on channel 2 in my sequence, moved it up to channel 1, and it played fine...moved it back to channel 2 and it continued to work fine.  so i am curious if anyone else has had this problem, and what the solution was.
  • Sun, Jun 18 2006 9:06 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,620
    Re: track-1 not found
    Here is what knowledge base says about this error message.
     though, I acknowledge, this won"t help you.
    Was it a stereo file ? If yes, it's important to know that Avid creates separate audio files, that is to say 2 files for 1 stereo audio file.It can happen that only 1 of both gets corrupted, but, reading your post, it seems the corrupted file recovered as you moved from 1 track to it's neighbour. Weird !
    Adrenaline MCA 2.8 XW8400 3Gb RAM DNxcel Board, 760 Gb striped SCSI media storage, 1.2 TB 4 X striped SAS 15 000rpm storage.----MC Soft 2.8 + Mojo HP XW8000... [view my complete system specs]
    sep
     Web site : www.audiacom.com
  • Mon, Jun 19 2006 12:26 AM In reply to
    Although this may not apply to you, there's another cause of "Track -1 Not Found".  Here's an example:  You capture 2 tracks of audio, and cut it into a sequence.  Later, you need to batch capture the same audio, but decide not to capture A2.  When you play the sequence, it is expecting an audio clip with 2 tracks, and only encounters a single audio track.  So, it's trying to tell you "1 track is not found", but words it as , "Track -1 Not Found".  When this is the case, you either have to recapture the audio with the missing track(s), or, re-cut in all the offending audio clips.
    (wwld)
  • Mon, Jun 19 2006 9:44 PM In reply to
    • stickboy
    • Posts 5
    • Points 45
    thanks for the responses..yes the files are stereo, and i realize that they are seperate audio files, it was just a little too coincedental that the only corruption was on right channel audio...my project is about 2.5 terabytes large, so this stuff is making me panic....in addition, when i deleted what was deemed to be "corrupt" media, i was unable to batch digitize the master clip..it kept kicking out saying batch dig complete, even with digitize only media that is offline disabled...
    i have worked around the problem so far, but i would like to toss around any ideas or suggestions
  • Mon, Oct 10 2016 5:07 AM In reply to
    • cozzie
    • Joined on Wed, May 23 2012
    • Posts 5
    • Points 45
    This drove me nuts until I checked the box in export options to mixdown audio tracks.
