Latest post Thu, Jan 10 2019 3:11 PM by JPBU. 3 replies.
  • Thu, Jan 3 2019 5:31 PM
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 141
    • Points 1,900
    Bin search problem
    I've installed the latest version 2018.12 and since then the "sift search" at the bottom of bins don't work anymore with custom columns as it did with the previous version. I have tried different views without success. Is there a way to have AVID "re-index" the field of custom columns ?
    Thank you.
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Tue, Jan 8 2019 3:37 PM In reply to
    • JPBU
    • Canada
    • Posts 141
    • Points 1,900
    Re: Bin search problem
    Anyone else having this issue of not being able to search custom columns ?
  • Tue, Jan 8 2019 7:52 PM In reply to
    You can throw the "Search Data" folder within the project folder away, and then it will re-index all bins.
    If your project isn't too large, this shouldn't be a big deal. If it's massive, this might take a while to complete.
  • Thu, Jan 10 2019 3:11 PM In reply to
    • JPBU
    • Canada
    • Posts 141
    • Points 1,900
    Thank You , I didn't know about that trick. Unfortunately, I just deleted it and after a rebuild, this does not change my problem. The search engine works, but I still can't use the search at the bottom of the bins to sift content from custom columns.
