Hello everybody. I have a problem with my subtitles. If I insert the subtitles by SubCap effect does not work on all video tracks. As soon as something lies on an overlying track, the subtitles are no longer displayed? For a better understanding, see two screenshots. Thanks for your help <3
No. 2
That appears to be working correctly. If you want the subcaps to appear at all times, they must be on the uppermost layer of your sequence.
thank you for your help. Unfortunately no, because then I do not see the subtitles ...
okay sorry. I have created a new video track V8 and now the subtitles are visible on all tracks. So it works. Many Thanks :)
gjango: thank you for your help. Unfortunately no, because then I do not see the subtitles ...
As you've discovered, moving V4 above V7 doesn't solve the problem because Avid still "sees" material on V4 "under" any track with a numerically higher track number.
gjango: okay sorry. I have created a new video track V8 and now the subtitles are visible on all tracks. So it works. Many Thanks :)
I'm glad you figured it out. :)
