Latest post Wed, Jan 16 2019 4:55 PM by Marianna. 23 replies.
Page 1 of 2 (24 items) 1 2 Next >
  • Wed, Jan 2 2019 1:56 PM
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Posts 52
    • Points 695
    2018.12 | Can't playback 2018.5-sequence | Error "Audio consumer duration differs"
    Happy new year everyone! :)
    I just installed 2018.12 to see the new features at work. As soon as I opened an old sequence (v2018.5) I got this error:
    After clicking "continue" I get this:
    The 50/50 method narrowed it down to a very few of the many audio suite plugins used in this and other sequences. (Mostly EQ3 1-Band and D-Verb.) Other parts, with or without audio suite plugins, can be in/out-previewed. I could only test it on a MacBook Pro (15-inch, 2017, 3,1GHz i7, macOS 10.13.6, AJA T-Tap v15.0.1.1) so far. Does anybody know a solution besides removing and reapplying the effects? Meanwhile I will once more switch back to 2018.5 ;) Thx & Cheers
  • Sun, Jan 6 2019 11:14 PM In reply to
    • palm
    • Joined on Mon, Aug 1 2011
    • Posts 7
    • Points 85
    Re: 2018.12 | Can't playback 2018.5-sequence | Error "Audio consumer duration differs"
    Had the same problem with a project started on 2018.1. Had to roll back to 2018.11.
    MacOS Sierra
  • Mon, Jan 7 2019 11:53 AM In reply to
    • Cutyes
    • Posts 52
    • Points 695
    That makes us three. (With the other thread http://community.avid.com/forums/t/196163.aspx)
    Maybe worth a closer look for one of your wizards, Avid? I wish I could use 2018.12 with my older sequences... :)
  • Mon, Jan 7 2019 2:00 PM In reply to
    • Posts 10,018
    • Points 215,695
    Cutyes
    what OS are you using on the Mac Pro?   I created a case for you Tobias.... and will do the same for the rest of the folks reporting this so we have multiple cases and get attention quickly.   Case # 03625127
  • Mon, Jan 7 2019 2:07 PM In reply to
    • Posts 10,018
    • Points 215,695
    palm:
    MacOS Sierra
    Hi there... I also created a case for you as well....   Case # 03625134.  I think Michael if we get a few cases with the same symptom it will be eaiser to fix.
    stand by
  • Mon, Jan 7 2019 3:09 PM In reply to
    • Cutyes
    • Posts 52
    • Points 695
    Hey Marianna,
    thank you for your help! :)
    I am the one with the MacBook Pro:
    15-inch, 2017
    i7 3,1GHz
    MacOS 10.13.6
    AJA T-Tap, Software v15.0.1.1
  • Mon, Jan 7 2019 10:36 PM In reply to
    • palm
    • Posts 7
    • Points 85
    Thanks for bringing this to attention, Marianna!
    Working on iMac retina 27“ late 2015 btw.
  • Tue, Jan 8 2019 11:38 AM In reply to
    • rabbitfire
    • Joined on Wed, Apr 3 2013
    • Posts 2
    • Points 30
    same here - any news?
  • Tue, Jan 8 2019 1:49 PM In reply to
    • Posts 10,018
    • Points 215,695
    palm:
    Hey there.....   Marcin responded to the case and is looking for some info from you.  Can you respond?
    "  Can you provide me some additional information regarding the issue? Is this happening just with projects created with previous version of Media Composer or there is no pattern there? (provided you had enough time to test the latest release).
    We would like to get same samples (media files, project) to try to reproduce the issue in house. I will be sending upload link to you soon.
    Thanks and regards,
    Marcin "
  • Tue, Jan 8 2019 1:51 PM In reply to
    • Posts 10,018
    • Points 215,695
    rabbitfire:
    Rabbitfire...   not yet still trying to reproduce.
    Can you provide:
    Computer?
    OS?
    MC version?
    Opening older projects or net new projects?
    If older projects, what version?
    • Posts 10,018
    • Points 215,695
    rabbitfire:
    Can you provide:
    Computer?
    OS?
    MC version?
  • Tue, Jan 8 2019 2:29 PM In reply to
    • rabbitfire
    • Posts 2
    • Points 30
    PC W10 2018.12
    Project created just before updating to 2018.12
    Removing some audio located on A1 and A2 solved the problem for me
  • Tue, Jan 8 2019 5:24 PM In reply to
    • willoswald
    • Posts 6
    • Points 70
    Yes just had this going from version 2018. to 2018.12. Windows 10 latest version updates. I can't even close down properly I have to crash out. Solutions please I can't move down the timeline at all even to remove EQ.
  • Tue, Jan 8 2019 6:23 PM In reply to
    • willoswald
    • Posts 6
    • Points 70
    Sorry should have been 2018.5 was the previous working version. Back to that version with a uninstall and reinstall.
  • Tue, Jan 8 2019 9:27 PM In reply to
    Same problem here, it happens when I render an EQ3 7-Band Audio Suite effect on a stereo music track. I can play again if I delete the renders, but not if I try another audio file or different EQ. Also, the sequence was created on 2018.12.
    MacBook Pro 15”, Intel Core i7 2.6, Amd Vega 16, 32gb RAM, Mac OS 10.14.2 [view my complete system specs]
