Latest post Fri, Dec 28 2018 2:57 PM by NYnutz. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Dec 19 2018 4:56 PM
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    Anyone know why Avid doesn't like this OP-1a MXF?
    Pop it in a numbered MXF folder but it hates it and just wants to quarantine it!
    Symphony 2018.11, Blackmagic Intensity Pro (cant get it working well in 4k though for client monitor - which was the point...), WIN 10 on 2000Mbps M.2 SSD, Nvidia Quadro K2000, Asus X99 Mobo, 4.0 GHz Hex core CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10
    VIDEO MEDIA PRODUCTION COMPANY AND FACILITIES CARDIFF, LONDON, BRISTOL, WALES, CRACKING PRODUCTIONS
  • Wed, Dec 19 2018 5:21 PM In reply to
    Re: Anyone know why Avid doesn't like this OP-1a MXF?
    Because Avid likes OP-Atom MXF in it's folders
    HP Z820, AVID MC 8.5 [view my complete system specs]
  • Wed, Dec 19 2018 5:34 PM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    Ahh - thanks - I had them the wrong way round in my head!Embarrassed
    Is there a quick re-wrap app as I think the actual codec is good?
    Cheers.
  • Wed, Dec 19 2018 5:45 PM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    And a suitable re-wrap app is called Convert V3. I just re-wrap as a .MOV and can AMA link sucessfully.
    All's well :-)
  • Wed, Dec 19 2018 6:20 PM In reply to
    Your source MXF file may be AMA-linked too (besides some codecs). Fast way - with ALT drag file to bin, then consolidate to wished disk, and no additional software is needed.
  • Wed, Dec 19 2018 7:15 PM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    I remember I used to drag files into bins - usually WAV audio files - but that hasnt worked for a long time.  Have had to manually navigate. I  will try the ALT drag.  Many thanks
  • Thu, Dec 20 2018 8:48 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 553
    • Points 7,055
    In case you're interested, Davinci Resolve can also export MXF Op Atom files from the deliver page. You can export from a timeline either as one file or individual files (one for each clip on the timeline).
    I've used this technique a number of times to convert heavyweight Red and dpx files to something like DNX36.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Thu, Dec 20 2018 9:20 AM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    Top tip for bigger projects - thanks Bruno :)
  • Fri, Dec 28 2018 9:41 AM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    Guys - just an update on this - Avid IS linking to OP-1a MXF files without unwrapping!  I think my initial test file for this workflow was corrupt.  I used Convert V6 to unwrap (when it works - tip always tick the 'use subfolder box') but accidentally didnt when the producer bought an ext HDD in and it linked no problem...  Verified its 100% OP-1a using Media Info :)
  • Fri, Dec 28 2018 2:57 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 336
    • Points 3,910
    Bruno M:
    something to keep in mind with this - in older versions of resolve, OP-Atom mediafiles were NOT usable in interplay. Standard media composer is perfectly happy with resolve generated OP-Atom. Have not yet tested with interplay 2018 or resolve 15.
    Dave
    "A very big network"
