Latest post Fri, Dec 14 2018 9:30 PM by jef. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Dec 13 2018 11:39 PM
    • chawilk
    • Vancouver Canada
    • Posts 61
    • Points 800
    XAVC-S Workflow
    Cheers,
    I'd very much appreciate some input on the workflow we're planning on using here to deal with XAVC-S footage from a Sony a6500.  The project is 1080 24p, Canon C100 A camera, Sony a6500 B camera.  It's a long feature length documentary with a great deal of footage.  Our experience with AMA has not been great on long projects, we have the power and storage space to edit with imported files.
    - For the C100 footage we'll import DNxHD 175
    - For the Sony footage we'll AMA link, then transcode as DNxHD 175 and edit with the transcoded clips.
    - At the end of the day we'll export the project in highest quality, with handles for the post lab to color correct & process visual fx.
    Is this workflow going to afford the best quality possible given the source material?
    Thanks for the help.
    MC 2018 4 PC. Intel Core i7 4930K 6 Core 3.4GHZ (3.9GHZ Turbo) 12MB Hyperthreading Corsair Vengeance Pro 32GB 4X8GB RAM, Nvidia Quatro P4000 Samsung... [view my complete system specs]
  • Fri, Dec 14 2018 8:42 AM In reply to
    Re: XAVC-S Workflow
    Last time I looked, I could't link to Canon 24P footage (C300). Better test or use a 3rd party transcoding method.
    iMac i5 27", 24GB RAM, OS 10.13.6 with Symphony 2018.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.13.6 with MC 2018.5 and BMD Ultrastudio... [view my complete system specs]
  • Fri, Dec 14 2018 6:24 PM In reply to
    • chawilk
    • Vancouver Canada
    • Posts 61
    • Points 800
    Re: XAVC-S Workflow
    Hi Roger.  Yes, I found Avid could not import Canon C300 without external program transcoding, but the C100 is a straightforward AVCHD codec which imports fine.  It's the a6500 XAVC-S Sony footage I'm wondering about.
  • Fri, Dec 14 2018 7:29 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,527
    • Points 45,365
    Re: XAVC-S Workflow
    My camera is XAVC-S, and I can link and transcode just fine (actually I usually don't even transcode; most of what I do involves nothing but straight cuts and fades). Once pieced together, I output an AAF, do any color corrections in Resolve, and master from there.
    Dave S.
  • Fri, Dec 14 2018 7:44 PM In reply to
    • chawilk
    • Vancouver Canada
    • Posts 61
    • Points 800
    Re: XAVC-S Workflow
    Thanks Dave,
    Right, I have no problem either linking & transcoding the XAVC-S footage.  I'm just hoping to confirm that this is the best possible way to handle the material.
    Charles
  • Fri, Dec 14 2018 8:59 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,527
    • Points 45,365
    Re: XAVC-S Workflow
    If you're mixing it with other media, transcoding everything to a common format is best. Plus it get's rid of any occasional stuttering from the XAVC-S.
    Dave S.
  • Fri, Dec 14 2018 9:30 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,338
    • Points 40,375
    Re: XAVC-S Workflow
    chawilk:
    Cheers,
    This seems like a very solid plan.  My only question, based on not knowing those cameras / codecs is are either of them making / recording 10 bit images?  If so you should be using the DNX 175x codec.  The "x" after 175 denotes 10bit.
    Jef
    Jef Huey
