Latest post Mon, Dec 3 2018 9:24 AM by tommix. 3 replies.
  • Wed, Nov 28 2018 12:59 PM
    • jrejre
    • Joined on Wed, Nov 28 2018
    • Posts 2
    • Points 30
    Avid Media Composer First crashes on start up - and I know why
    I have a freshly installed iMac runing Mojave 10.14.1 on an APFS formatted drive. I installed Media Composer First and rebooted as requested.
    I tried to start Media Composer First and it crashes immediately. I'm pasting the report window information below, but in summary it seems to be the case sensitivity of the file system. Look at this error:
      Library not loaded: @executable_path/libMvCore.dylib
    But the file is named this:   libMVCore.dylib
    So I made a renamed that file, but then I get another error. The app is looking for:
      libUIShell.dylib
    But the file name is actually
      libUIshell.dylib
    I could go through and try and fix all of these errors, but there could be dozens of them. Perhaps the Avid installer is either not case-sensitive aware, or is not testing for case-sensitivity, or who knows what? But whatever, out of the box I cannot use Avid Media Composer First.
    J.
    Full report:
    Process:               AvidMediaComposer [2472]
    Path:                  /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
    Identifier:            com.avid.mediacomposer
    Version:               18.11.0.49905 (18.11.0)
    Code Type:             X86-64 (Native)
    Parent Process:        ??? [1]
    Responsible:           AvidMediaComposer [2472]
    User ID:               501
    Date/Time:             2018-11-28 12:47:02.242 +0000
    OS Version:            Mac OS X 10.14.1 (18B75)
    Report Version:        12
    Anonymous UUID:        51BBECE5-A763-B2FC-2218-204DAE0B0B65
    Time Awake Since Boot: 1000 seconds
    System Integrity Protection: enabled
    Crashed Thread:        0
    Exception Type:        EXC_CRASH (SIGABRT)
    Exception Codes:       0x0000000000000000, 0x0000000000000000
    Exception Note:        EXC_CORPSE_NOTIFY
    Termination Reason:    DYLD, [0x1] Library missing
    Application Specific Information:
    dyld: launch, loading dependent libraries
    Dyld Error Message:
      Referenced from: /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
      Reason: image not found
    Binary Images:
           0x1084c6000 -        0x10a64bfc7 +com.avid.mediacomposer (18.11.0.49905 - 18.11.0) <B599DB69-AF3E-3D16-A30D-4F9B89EBF3D6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
           0x10ba24000 -        0x10bf4eff7 +org.qt-project.QtCore (5.7 - 5.7.0) <111028E5-0C7D-32E3-8771-90B7C3C1EB5A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
           0x10c1af000 -        0x10c624fff +org.qt-project.QtGui (5.7 - 5.7.0) <C79AADBC-57BD-3FA7-AFD7-0AF7FFD17988> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
           0x10c8ea000 -        0x10c91dff7 +org.qt-project.QtXml (5.7 - 5.7.0) <DB25ADC7-5FDA-3230-895E-3E012CD8C247> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtXml.framework/Versions/5/QtXml
           0x10c954000 -        0x10c98fff7 +org.qt-project.QtSvg (5.7 - 5.7.0) <A6743CF8-CD49-39CE-A037-1357DAE2D28E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtSvg.framework/Versions/5/QtSvg
           0x10c9ce000 -        0x10cad8fff +org.qt-project.QtNetwork (5.7 - 5.7.0) <AF45810A-71FD-30BA-A530-6F01D5F6344E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtNetwork.framework/Versions/5/QtNetwork
           0x10cbc4000 -        0x10d0caff7 +org.qt-project.QtWidgets (5.7 - 5.7.0) <DE11D40E-7908-3220-88CD-5B0C7184EBA9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
           0x10d484000 -        0x10d4b7fff +org.qt-project.QtPrintSupport (5.7 - 5.7.0) <28171874-E23A-37B9-A82F-500D7896FC71> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
           0x10d4ff000 -        0x10d565ffd +com.SafeNet.SuperPro (SuperPro version 6.6.0 - 6.6.0) /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SuperPro.framework/Versions/A/SuperPro
           0x10d57e000 -        0x10d6c0ff3 +libicuucAvid.dylib (0) <D6901B2C-A48C-39D0-AE61-645F7ECC9E67> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicuucAvid.dylib
           0x10d737000 -        0x10d90dff3 +libicui18nAvid.dylib (0) <B35B55DC-BCA9-37E2-AAFB-FFA6DDA94D40> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicui18nAvid.dylib
           0x10da0c000 -        0x10da14ffb +libicuioAvid.dylib (0) <C8C51C88-D0F4-3DD6-BCB6-04044BCFBB66> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicuioAvid.dylib
           0x10da23000 -        0x10f3bbfff +libicudataAvid.dylib (0) <13FECFE0-CF5B-3F16-90E4-ECE130A25540> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicudataAvid.dylib
           0x10f3f2000 -        0x10f430fff +org.qt-project.QtOpenGL (5.7 - 5.7.0) <B813F5ED-91D3-3276-966C-856054678F7C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtOpenGL.framework/Versions/5/QtOpenGL
           0x10f481000 -        0x11350e6c7 +org.qt-project.Qt.QtWebEngineCore (5.7 - 5.7.0) <E95152F6-379E-3C7A-A3D5-83C5A86353E7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebEngineCore.framework/Versions/5/QtWebEngineCore
           0x117534000 -        0x117564ff7 +org.qt-project.QtWebEngine (5.7 - 5.7.0) <58FA5EE5-8689-3138-8680-7CFAC3CD7599> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebEngine.framework/Versions/5/QtWebEngine
           0x1175bf000 -        0x1175e1ff7 +org.qt-project.QtWebEngineWidgets (5.7 - 5.7.0) <1A129DE1-5D29-3273-8B4E-303279415594> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebEngineWidgets.framework/Versions/5/QtWebEngineWidgets
           0x117625000 -        0x117645fff +org.qt-project.QtWebSockets (5.7 - 5.7.0) <BCA56214-905A-3CE2-AF87-10CBC35FCCF4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebSockets.framework/Versions/5/QtWebSockets
           0x11766b000 -        0x117680fff +org.qt-project.QtWebChannel (5.7 - 5.7.0) <6514BD31-A5D5-3136-A121-DC90E0FE8300> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebChannel.framework/Versions/5/QtWebChannel
           0x1176a1000 -        0x1176aaff7 +org.qt-project.QtMacExtras (5.7 - 5.7.0) <7F5052D8-B99D-3105-B803-F9459B8B5B40> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras
           0x1176bd000 -        0x11780fff7 +org.qt-project.QtSql (5.7 - 5.7.0) <AD3C640A-7210-3304-95DC-9A951399F3B1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtSql.framework/Versions/5/QtSql
           0x11786f000 -        0x1179c5fef +libELF_libc++_xcode.dylib (0) <CEDB78E6-821F-3E56-81C4-683CED40F825> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libELF_libc++_xcode.dylib
           0x1179f2000 -        0x117bf9fd7 +com.avid.FTF (1.7.1 - 1) <0C12CA45-D3E1-3A1E-B4C9-64BCC072571C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/FTF.framework/Versions/A/FTF
           0x117cac000 -        0x117df9fff +gk.dylib (0) <BC8B9FE8-0733-3ABB-88E5-EA5E36EAFE0B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/gk.dylib
           0x117e73000 -        0x117e80ff7 +libjpegV4.dylib (1) <0B49A8C3-09BB-9697-D719-F60621D279E0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libjpegV4.dylib
           0x117e8a000 -        0x117f07fff +com.avid.MCCloud (1.0 - 1) <750660EF-1959-3F10-85E4-71CBBA151E25> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/MCCloud.framework/Versions/A/MCCloud
           0x117fa1000 -        0x117faafff +com.googlecode.google-breakpad (1.0) <811F09F8-440F-3E0A-A2ED-745F1D92F2E9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
           0x117fc4000 -        0x118025fff +libAMPIHost.dylib (0) <922DC0F2-17D7-39BD-9F75-B71728D77A61> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAMPIHost.dylib
           0x11808d000 -        0x1180ecfff +com.avid.DMF (1.0 - 1) <F6218731-C651-3F29-B1B9-319776E2D635> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DMF.framework/Versions/A/DMF
           0x11813f000 -        0x118402ff7 +com.avid.UIShellQt (1.0 - 1.0) <BC4C39A3-AD51-3DCF-89DF-340497CF975C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/UIShellQt.framework/Versions/A/UIShellQt
           0x1185e9000 -        0x1185edfff +com.avid.backgroundqueue (1.0 - 1) <E6549056-5AEE-31EC-81D0-9E17B3FEA161> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/BackgroundQueue.framework/Versions/A/BackgroundQueue
           0x118606000 -        0x118707ffb +libAed.dylib (0) <F63D399F-CF67-34A2-B982-74EA60CB07FE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAed.dylib
           0x1188ce000 -        0x1189bffff +libAeu.dylib (0) <5BEC864C-42E1-34BB-A130-6780D3947BE1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAeu.dylib
           0x118b31000 -        0x118b40ffb +libAut.dylib (0) <EA03D166-3730-3A88-84E5-FF3965603AA9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAut.dylib
           0x118b5f000 -        0x118f65fff +com.avid.AvidCore (5.12.0 - 5.12.0) <A05E9C91-0E5E-3E32-BEB7-33ECD6876010> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCore.framework/Versions/A/AvidCore
           0x1192cb000 -        0x1192ecff7 +com.avid.AvidCoreServices (5.12.0 - 5.12.0) <2315943A-1499-3BE8-A9FA-DBF2403C132E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreServices.framework/Versions/A/AvidCoreServices
           0x11933e000 -        0x119354ff7 +com.avid.AvidCoreThreads (5.12.0 - 5.12.0) <7C3C2821-D86C-3E68-BF31-C9A85ECB487E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreThreads.framework/Versions/A/AvidCoreThreads
           0x11938b000 -        0x11938fff7 +com.avid.AvidCoreUtils (5.12.0 - 5.12.0) <C1E666F2-FC0C-3869-953B-10EF179B5824> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreUtils.framework/Versions/A/AvidCoreUtils
           0x1193a4000 -        0x1193c1fff +com.avid.DigitalIO (5.12.0 - 5.12.0) <FF56413B-49F3-34C2-B3BF-3DACEA6D3BA4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidDigitalIO.framework/Versions/A/AvidDigitalIO
           0x119412000 -        0x11945fff7 +libACME.dylib (0) <C2B7BF97-C49C-39AF-957C-092E46724876> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libACME.dylib
           0x1194cc000 -        0x11951fffb +com.avid.AMI (1.0.0 - 1.0.0) <618BC15F-3A22-34DF-A7B3-BFFA49FCBD00> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Ami.framework/Versions/A/Ami
           0x119596000 -        0x119693fff +libAuiCore.dylib (0) <A457649E-EAF2-3A6A-A93D-E0E480A93760> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAuiCore.dylib
           0x11b6f0000 -        0x11b76e6a7  dyld (635.2) <1780094A-8FE2-3EAA-B4A3-C4CF14BC5196> /usr/lib/dyld
        0x7fff59984000 -     0x7fff59993ff3  com.apple.opengl (17.0.37 - 17.0.37) <6BCCA53E-5621-32ED-BA9A-38B1C2499ED5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff5b295000 -     0x7fff5b5bbff7  com.apple.security (7.0 - 58286.220.15) <6725D63D-378F-3751-8602-3122016E4AA4> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff7ab47000 -     0x7fff7ab9bff3  libcurl.4.dylib (105.200.2) <607613FE-3D84-3035-9C79-C6F72AF287D7> /usr/lib/libcurl.4.dylib
    Model: iMac14,2, BootROM 133.0.0.0.0, 4 processors, Intel Core i7, 3.5 GHz, 32 GB, SMC 2.15f7
    Graphics: NVIDIA GeForce GTX 780M, NVIDIA GeForce GTX 780M, PCIe
    Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3831554738454655352D474E4C2D46
    Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3831554738454655352D474E4C2D46
    Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3831554738454655352D474E4C2D46
    Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3831554738454655352D474E4C2D46
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x111), Broadcom BCM43xx 1.0 (7.77.61.1 AirPortDriverBrcmNIC-1305.2)
    Bluetooth: Version 6.0.9f2, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: APPLE SSD SD0128F, 121.33 GB
    Serial ATA Device: APPLE HDD ST1000DM003, 1 TB
    USB Device: USB 3.0 Bus
    USB Device: Expansion Desk
    USB Device: BRCM20702 Hub
    USB Device: Bluetooth USB Host Controller
    USB Device: FaceTime HD Camera (Built-in)
    Thunderbolt Bus: iMac, Apple Inc., 23.10
  • Wed, Nov 28 2018 8:15 PM In reply to
    • Posts 10,157
    • Points 217,360
    Re: Avid Media Composer First crashes on start up - and I know why
    Hello there
    Everything looks good hardware wise, so I would remove all Avid files - uninstall.  and download it and reinstall it again.
  • Thu, Nov 29 2018 5:46 PM In reply to
    • jrejre
    • Posts 2
    • Points 30
    Thank you for the reply. I tried that but the problem is the same.
    J.
  • Mon, Dec 3 2018 9:24 AM In reply to
    • tommix
    • Joined on Tue, Oct 14 2008
    • Posts 207
    • Points 2,545
    Tonight I upgraded to on 10.14 and it went smoothly.
    Don't doubt the file names you oun, but I doubt that is your problem.
